Volume calculator
 1-15  16-35  36-55  56-75  76
7421.36 In reply to 7421.2
Hi Moi'ers
Thanks for all great tips!
Much appreciated :)
/Stardust
7421.37
Hi all!
First message here at forum although I've red and learned a lot from it.
First of all, congratulation to Michael for this amazing software and also Max & Co for great add-ons and scripts.
Now the reason which I finally decided to register and post :-)
Would be possible to add to this script a checkbox or something to locate (by creating a cross or a point) the solid center masses? Always considering the solid as homogeneous of course...
Best regards!
D.
7421.38 In reply to 7421.37
Hi dsicart, I'm glad you are liking MoI!
Just in case nobody is able to modify the script as you are asking for, your next best be would be to use the trial version of Rhino - load your 3DM file into there and then select it and run Rhino's Analyze > Mass properties > "Volume centroid" command. The centroid point will be printed on the command line and you can select it and use Ctrl+C to copy the text to the clipboard.
Another helper program that could be useful for this is ViaCAD 2D/3D which is not expensive and has some various tools in it like this that MoI does not have quite yet.
7421.39 In reply to 7421.37
dsicart
I think it's possible.
7421.40 In reply to 7421.39
v.1.2.2015.08.29
[Added] Center of mass calculation (I hope it works :)
[Added] Surface area parameter
EDITED: 7 Mar 2022 by SMIRNOV
7421.41 In reply to 7421.40
Thanks Max!
It will be really useful!
Best regards from Barcelona.
Size: 475.1 KB, Downloaded: 171 times, Dimensions: 1920x1050px
7421.42
Hi Max,
Is it possible to calculate surface area of selected faces only?
Mik
7421.43 In reply to 7421.42
Hi Mik, good idea! I'll make it today or tomorrow.
7421.44
Thanks again Max! This is fantastic!
Michael T.
7421.45
Hi Max,
This is a great tool, thank you.
I think this is a big ask, but would it be possible for 2 or more solids of different densities to have its combined centre of Gravity worked out?
James E
www.jameselliott.co.uk
7421.46 In reply to 7421.43
Thank you very much , Max, it would be great.
Mik
7421.47 In reply to 7421.45
The equation to find combined centre of Gravity, is explained very well here:
https://www.youtube.com/watch?v=KMDY-hexpZ8
mass1 = vol1 * density1 , centered at point mass m1.
mass2 = vol2 * density2 , centered at point mass m2.
d = distance between (center of mass of m1) and (center of mass of m2).
x = distance from (center of mass of m1) to the point on the line between m1 and m2, which is the combined centre of Gravity.
m1 * x = m2(d-x)
x = (m2 * d ) / (m1 + m2)
They say is the "same" for torque. (No inverse square law needed.)
(x is not necessarily the x-axis), so x,y,z coordinates of the points may be used, or a cplane making d along the x axis...)
7421.48
CVolume v1.3
[added] enhanced surface mode. How you can use this script with faces and separate surfaces.
Marbleman
Hi James. Yes, this is possible, but I need to think about concept. Give me a week.
7421.49 In reply to 7421.48
Excellent Max,
thank you very much, you are King of Scripts :-)
Regarding centre of gravity ... it will be fine to have set of styles which represents certain material = density.
Kind regards,
Mik
7421.50 In reply to 7421.49
Mik
Yes, I have the same thoughts.
In fact the technical part don't bother me. There are pretty simple calculations. First I need to think about global internal structural changes. It is much more difficult task.
7421.51
Yes, of course, choosing the best concept is always big task and calculation of CoG will be very useful feature for modelling of complex assemblies.
Kind regards,
Mik
Do you confirm or not that Center of Mass can be calculated between 2, 3, or more volumes in the same time inside the present plugin? (same density)
7421.53 In reply to 7421.52
Yes, I confirm it. :-) 2, 3 and more.
7421.54 In reply to 7421.53
Terrific!
7421.55
Thanks Max,
I think you're the master!
James E
Show messages:  1-15  16-35  36-55  56-75  76
