Flow as an "unfold tool"
 1-6  7-26  27-28
7406.7
thank you for reply. You are right that this way of unfold objects is reasonable only for specific structures. Practically for simple models with parallel side walls, which is modelled with specific rule.
I've modelled next test objects and unfold them in AutoPOL (http://www.autopol.com/products/unfolder/introduction/introduction.asp?sidebar=intro_u)
Left object was modelled by loft command, object on right is modelled via extrusion and union.
imported DXF from AutoPOL - 3dm, attached
I wanted to see the difference of unfolding process, detail of bended part of models is here:
Of course I would obtain same results by copy of outer surface of model - rotate axis of separated faces, calculate length of radius, joint together and export DXF.
Question is, if it's possible to write script which can do this operation automatically. Length of radius should be let as variable which take into account material and tooling.
MoI is excellent CAD modeller and construction program and this utility would help a lot for metal sheet parts, which is quite often part of more complex assemblies.
Maybe such scripts will be nice exercise for some experts from this amazing forum.
Here is the test of Cloth script written by Max Smirnov, for instance :-) http://moi3d.com/gallery/viewitem.php?id=790
Mik
7406.8 In reply to 7406.7
The Offset function and UnWrapCurve script can't help you for some actions ?
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5136.1
EDITED: 21 May 2015 by PILOU
7406.9
you mean probably rotation faces without drawing auxiliary circles, it means choosing edge as axis of rotation and then offset the face.
Because it's possible to calculate compensated length of radius, maybe it's more handy to rotate the face using centre of radius and then move the face in right direction by calculated distance.
Mik
7406.10
Understand you meant Pilou, I didn't see the thread link in your previous post.
Mik
7406.11 In reply to 7406.7
Hi Mik,
I'm not really sure if it's possible with the current stuff that's available to scripts... For example it's difficult for a script to analyze different geometric features of surfaces like find the center point of your bend, there just isn't currently a lot of functionality exposed for scripts to gather that type of information.
In the future I want to enhance the script layer to make more things available for scripts to access, something like this probably would not be feasible until that time.
7406.12 In reply to 7406.11
The function Join don't keep multi colors of the curves multicolored joined!
So when you Unwrap a curve "joined" it's monoclor so you can't see the differents extremities! :)
Flow yes! :)
So Flow the curves on their Unwrap! ;)
Have you the good result of your Unfold with this method ? Alas seems not!
script:/* Past Calculate lenght of selected curves inside the clipboard */ var crvs = moi.geometryDatabase.getSelectedObjects().getCurves(); var len = 0.0; for ( var i = 0; i < crvs.length; ++i ) len += crvs.item(i).getLength(); moi.copyTextToClipboard( len );
Seems the blue unfolded by Flow is not exactly the same or this tolerance is sufficient?
7,8539 8162216791 Blue Curve
7,8539 5062752401 Blue Unfolded by Flow
7,8539 8162216791 Unwraped is perfect!
So seems better use some Unwrap "unfold" method than Flow "unfold" method! :)
When you try Flow on the same place of some curves you can name them before then over put them
Select them with the Browser / Call the function Flow / Hide origin curve / Point the Base Curve etc...
Alas that change not the relative bad result of the Flow method! :)
7406.13 In reply to 7406.11
OK, understand, don't worry and thank you for your time.
Mik
7406.14 In reply to 7406.12
many thanks for your reply. I'm not sure, but I think that I do the similar thing. When I prepare geometry to Flow - "Unfold" process I highlight edges of part profile first, then I use Offset command to take Base curve which goes in the middle of material thickness. Offset curve is Joined automatically. This curve I Unwrap as a target curve. After that I highlight part (solid), point the Base Curve, then Target curve and then I obtain planar solid. If I color faces before Flow, so result is planar solid with coloured faces. Each unfolded face correspond to original.
I've tried to use your script but I'm not sure if I use it correctly. I choose some curve run the script by shortcut and in clipboard is saved length of selected curve.
May I ask you for explanation in more details, please.
Thanks a lot.
Mik
7406.15 In reply to 7406.14
<<< I choose some curve run the script by shortcut and in clipboard is saved length of selected curve.
Yes it's exactly this! :)
The value of the lenght of any curve(s) selected is pasted in the ClipBoard!
So if you have some NotPad open somewhere you can read it after copy the clipBoard inside! :)
Not very speedy but better than nothing! And very informative! :)
Another thing is existing! (maybe not very adapted to your case but...
CurveLengthBeingDrawn :)
http://kyticka.webzdarma.cz/3d/moi/#CurveLengthBeingDrawn
or on my page in French ;)
http://moiscript.weebly.com/curvelengthbeingdrawn.html
EDITED: 22 May 2015 by PILOU
7406.16
That's an interesting script there, Pilou! I somehow missed that before.
Any idea if this can work during the editing of a curve as well?
Might be useful when trying to keep the length 'constant' while reshaping the curve by its points.
7406.17 In reply to 7406.16
<< Any idea if this can work during the editing of a curve as well?
Alas not with this version!
7406.18
There are plenty of unfold software tools. I would look at this one at it opens Rhino / Moi 3dm files . Its very clever, as it takes material thickness into account.
http://laminadesign.com/
Size: 38.6 KB, Downloaded: 163 times, Dimensions: 560x420px
Size: 32.8 KB, Downloaded: 160 times, Dimensions: 560x420px
7406.19 In reply to 7406.18
Not sure that it developps object as volume result ? Only as surface ...
EDITED: 23 May 2015 by PILOU
7406.20 In reply to 7406.19
Frenchy: Yes, the result is a surface, but this surface is calculated depending on the material and the material thickness to unroll. Let me cite the manual:
<snip>
Material: Use the "Material" menu to select the material (e.g. paper, steel, PETG) and material thickness to use. Lamina will take your material and its thickness into account when designing the 2-D cut path, to assure a proper fit of all the final pieces
</snip>
7406.21 In reply to 7406.20
Thx for the Info! After all is depending of what is wished...
7406.22 In reply to 7406.21
I own lamina. It allows you to flatten non-developable surfaces also.
Frenchy, the "not a volume" of a flattened object is just a thickness...
7406.23 In reply to 7406.22
So ...like SpaceClaim above ? (message 3) or this one
EDITED: 26 Jun 2019 by PILOU
In case of!
Remember there is a little free plugin for SKetchUp by Sdmitch : Sheet Metal Bender
http://sdmitch.blogspot.com
The last free version of Sketchup who can use Plugins is the SketchUp Make 2017 !
Curviloft by Fredo6
For something without "gorge" there is the native function!
EDITED: 27 Jun 2019 by PILOU
7406.25 In reply to 7406.24
Hey Pilou,
I hope life is good!
I see no images on my end :(
7406.26 In reply to 7406.25
sorry images come from an external forum so i will change that in a minute!...
Show messages:  1-6  7-26  27-28
