Braids
 1-5  6-25  26-30
7405.6 In reply to 7405.5
Thank you Michael.
5-Stranded "Flat" braid:
I am having trouble with step 17, smoothing the polyline with Autodest 3DS Max smooth command.
http://kevinjohn3d.blogspot.com/2007/12/creating-braid-in-3ds-max-method-2.html
What is the appropriate Moi command to do this smoothing?
I tried Fillet, which reduces amplitude in Top View, and the outer lobes are different radii.
I tried through point curve, which also does not give the same result.
Will try again tonight.
Also, learned a new way to tie shoelaces :-)
EDITED: 7 Jan 2022 by BEMFARMER
7405.8 In reply to 7405.7
Excellent the video! (youtube is more speedy than Krosoft one! ;)
Here is a draft of a Braid script.
BraidLF is a script which creates “flat” Braids in the Computer Aided Design program Moment of Inspiration.
The script is based upon periodic sinusoidal Lissajous curves, used as a racetrack, to model the centerlines of the strands.
A Sweep of the strands may be done with a circle, or other curve.
I'm working on a pdf file with further information and research papers utilized.
Replacing the Lissajous curve with a similar Nurbs curve could improve the braid.
Only 1 by n Lissajous curves are used at this time.
EDITED: 12 Oct 2020 by BEMFARMER
A draft pdf on the Braids is attached, with references.
Draft 02 of the script enables display of the racetrack.
Sweep is not done in the script. The Moi Sweep command works well.
Hi Michael
While trying to duplicate a Bezier curve, for use in a Braid, a strange result happened.
Zooming in at or near the origin causes the two Blue Blend curves to straighten on the screen view.
A PNG of the Bezier "figure8" is the image to reproduce in Moi.
The two outer arcs were duplicated with an arc, and two control points moved slightly.
(One of the moved locations on the upper left is in purple.
The ends of the modified arcs were G1 blended, to match the center Red X-shaped curves.
Zooming in causes the "error."
Question 1: Why?
Question 2: Do you have any tips, or references, to how to convert the Bezier curve into Nurbs?
I'm guessing that there is no way for a Moi user to plot a Nurbs equation without delving into the .3dm file format and C++ code.
(I recall seeing some very basic .3dm file C++ code on the Rhino site a while back.)
3dm file attached. There is an image file inside the .3dm.
Edit: Rebuild corrects the "Display Anomaly."
EDITED: 6 Jun 2015 by BEMFARMER
7405.12 In reply to 7405.11
> Question 1: Why?
It's a display glitch that can happen with Beziers that have a particular "S" type shape with the start and end tangents going in the same direction. It's unfortunately not easy to fix since the fix involves more thorough tolerance testing of the polyline approximation of the curve, and more testing is not good for performance.
So basically fixing this bug would cause some slow down for drawing all curves. Since it happens rarely and will incur a performance penalty to fix I have not tried to fix it so far.
There's a more detailed explanation here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4101.2
NURBS are basically a generalization of Beziers, if you have a NURBS curve with only one span in it (meaning the number of NURBS control points = curve degree + 1 like 4 control points for cubic), that NURBS curve will be a Bezier.
So to convert from a Bezier to NURBS it's pretty simple, you just make a NURBS curve that has the same degree as the bezier and has the same control points in it, and just give it a single span unit length knot vector.
That's correct, currently all the detailed low level NURBS information like curve degree, control point weights, and knot vector are not set up to be accessed by a script as of yet. But yes if you are writing C++ code you can use the OpenNURBS library to open a 3DM file and get at that information.
7405.13 In reply to 7405.12
Should this script be called _RaceTrack or _BraidTrack?
Edit: The script will be called _BraidTrack, and is in the zip _BraidTrack.
The script creates curves from points on a racetrack curve.
The racetrack curve could be 3D and closed or unclosed, but for this description, the racetrack is considered to be a 2D curve in the Front view.
The racetrack could be a circle, ellipse, polygon, "figure 8," multilobed figure 8, or Lissajous curve for a Braid.
The starting points of the curves are positioned as points on the racetrack curve.
Each point may represent the start point of the centerline of a Braid strand.
The points are imagined to be travelling along the curve in time, at constant speed.
The points are arrayed along the racetrack with perhaps 200 copies, each position a different Time.
The y-coordinates of the arrayed points are modified by adding fractions of Time, ( fractions of y distance.)
The 3D positions of the centerline points are plotted with their y-coordinates as Time.
Each point has two possible directions of travel. Array seems to work well in selecting the direction.
Running FLIP changes the direction of travel, with the same result as a mirror. (More remarks are in .js file.)
Edit: The last image is of a pentagon racetrack, with loft of the curves.
Size: 57.9 KB, Downloaded: 103 times, Dimensions: 91x264px
7405.15 In reply to 7405.14
Nice work on this, as well as all your other scripts.
For want of a better name, I'm guessing that "BraidTrack" is more descriptive...
HTH, Colin
7405.16 In reply to 7405.15
Thanks Colin.
_BraidTrack it is.
The topic could use some more study. Right now the racetracks are just guesses.
The racetrack has to be a closed curve, for the points to Array Curve properly,
because for an open curve, the only points that ArrayCurve on the curve are Start and End points.
I Flowed a sine wave onto a circle, but did not quite get it closed. (It looked closed from a distance)
Array Curve of points at miscellaneous points on the curve gave weird (but correct) results.
7405.18 In reply to 7405.14
Very cool. Good work!
BraidTrack does helices also. Moi already has a Helix command.
A swept double Moi helix, (not shown,) looked very similar to the left pair.
The colors are Pantone colors of the year.
EDITED: 5 Mar 2020 by BEMFARMER
Size: 15 KB, Downloaded: 73 times, Dimensions: 62x42px
Regarding Rope Mats and Rosettes:
https://www.ntnu.no/documents/2004699/12108297/Booklet+3.3.pdf
Here is a 7 bight Turk's Head knot template:
_FxGraph3D a*cos(-3*v)+b*cos(4*v)+c*cos(11*v);a*sin(-3*v)+b*sin(4*v)+c*sin(11*v);0;0;6.283185307179586;0;6.283185307179586;0;500;1.6;5.4;1.2;UV
The 2D curve was swept with a line segment to get 2 more curves from edges.
The over/under crossing remains to be done, perhaps with blend. A script or process to do the crossing would be helpful.
I did write a preliminary .js .htm script, but the formula is presented here in _FxGraph format.
To cover the lissajous rope mats, Turk's Head mats, twisted rosettes, rattan rosettes, and higher orders,
would involve several scripts, or a bunch of submenus. Doing several _FxGraph formulas could also be done.
EDITED: 24 Jun 2016 by BEMFARMER
Size: 109.7 KB, Downloaded: 80 times, Dimensions: 160x158px
Here is a different script from the previous post.
The BraidedBands script creates knots that are commonly known as "Turk's-Head knots"
References with more information:
http://www.mi.sanu.ac.rs/vismath/pennock1/index.html
http://www.mi.sanu.ac.rs/vismath/pennock/index.html
Cylindrical equations are used to model two types, Disk, and Cylindrical (Tubular), which may be physically manipulated into each other.
Definitions:
A Bight is a scallop or curve of the rope or cord, at the rim of the knot,
where the cord changes direction. The count of the Bights can be made at
the top rim, or the bottom rim of a cylinder, or the outer or inner rim of a disk.
Bights is a column count, or a radial column count, and is >= 2.
A Lead is the number of revolutions the cord makes around the center of the disk or cylinder, for one Ply only.
The Lead is a ""row count."" Leads is >= 2, for a knot, or no knot will occur, or an unknot.
Per the reference, if a line is drawn from the origin, the number of times the curve crosses the line, is the Lead,
provided Bight and Lead have no Common Divisors.
The Ply count is the number of "parallel" strands of the single cord in the knot.
The GCD (Greatest Common Divisor) of (Bights, Leads) must be equal to 1, or multiple cords will be needed for the knot.
The mathematical knot is a closed curve, and can be a pattern for a physically braided knot.
The physically braided knot is one rope or cord, woven in "parallel" Ply's, with two ends.
Cylindrical coordinates are converted to Cartesian coordinates.
Pipe is handy.
I would like to reconcile these knot formulas with the previous rope mat formulas.
EDITED: 20 Feb 2018 by BEMFARMER
Size: 83.7 KB, Downloaded: 49 times, Dimensions: 153x160px
7405.22 In reply to 7405.21
Brian,
Another non-virtual product of another of your scripts: http://www.thingiverse.com/thing:1955972
Mike.
Size: 510.9 KB, Downloaded: 85 times, Dimensions: 1200x910px
Linearizing a Baided Band.
The Braided Band script produces a class of knots, commonly known as "Turk's head knots", (There is no cultural stigma intended.) There is a "disk" version, and a "cylindrical" version, which are topologically the same, as a flexible physical model can be manipulated to either form. The inside center edge and outside edge of the disk version are equivalent to the top and bottom edge of the cylinder version. The disk version can be thin, and the cylindrical version can be thin walled. See the link to Skip Pennock's paper, for detailed descriptions.
Leads are the number of trips around a cicle. (= 2*PI*Leads)
The Braided Bands are defined parametrically in cylindrical coordinates.
It comes to mind that a Braided Band could be unrolled, to give a straight braid or weave. Better yet, rather than circularize the cylindrical coordinates and then unroll them, just present the cylindrical coordinates as linearized. This was accomplished using the equations for the cylindrical version, in the BraidedBands3 script.
z coordinates are the same.
y coordinates are the thickness.
x coordinates are the arcLength, MidrangeRadius * theta2.
For a 7 Bight, 4 Lead Linear Band, the result is ONE curve, with sine and cosine bends, rather than 4 curves. There are 21 cycles.
For relatively prime Bights and Leads, The number of cycles is q * ( p-1 ). = Bights * ( Leads - 1 ).
The curve can be divided into 4 pieces.
Place a point at the start of the curve, and ArrayCurve the point on the curve, using a value of 5. (5 = (Leads+1)).
Trim the curve with these points, resulting in 4 curves.
Move the 3 curves on the right, to the left, back to the origin.
The result is a 4 curve weave, which can be swept with a circle, usually the
diameter of the circle to use is the cord diameter.
An end view of the curves looks like a "race-track".
This could be scripted, or the 4 curves formed initially at 2PI intervals, either by script, or by nodeeditor.
BraidedBands3Alpha is a quick kludge modification. The menu should be changed to have a Build menu. For Disk, checkbox Disk. For Cyl, do not checbox Disk, nor Straight. For Straight, checkbox Straight, but NOT Disk.
The weave unit can be chained, end to end.
The chain should be flowable to some other curve, kind of like chain script.
A circle sweep bug was found. The bug was the same in V4 and V5Beta.
For some weaves, a circle will not sweep two selected curves correctly. A circle will sweep ONE selected curve at a time.
Some other weaves sweep multiply selected curves jus fine.
Multiple Ply's should be do-able, with more scripting.
image host
Here is the "race-track" end view:
image host
Edit, Version 3 alpha deleted. See Version 4 in a later post.
EDITED: 16 Apr 2022 by BEMFARMER
7405.24 In reply to 7405.23
A BraidedBands script with a Build menu has been created.
Getting the unrolled type with pLeads curves is being difficult.
Anyway, there is some discrepancy in the formulas??? re division by pLeads???
EDITED: 15 Apr 2022 by BEMFARMER
7405.25 In reply to 7405.24
Success with unwrap of Tube.
Division by (pLeads-1) was the key.
Version BraidedBands4 almost done.
Show messages:  1-5  6-25  26-30
