Dimension tool (as in sketchup)
 1-7  …  48-67  68-87  88-107  108-127  128-138
7403.88 In reply to 7403.84
hi Max
in french : BRAVO monsieur SMIRNOV , vous etes un grand monsieur !
Many thanks MAX , you are great ! - Максим, спасибо
Chri
EDITED: 9 Jan 2021 by CHRI
7403.89 In reply to 7403.88
7403.90 In reply to 7403.89
7403.91 In reply to 7403.90
That is just awesome!! Thank you Max!
7403.92 In reply to 7403.90
EDITED: 29 May 2020 by CHRI
7403.93
Release candidate ;) v.99
Added:
Feet/Inches format
Angles > 180
Type names
Type 6 activates circular mode automatically
EDITED: 7 Mar 2022 by SMIRNOV
Near perfection! ;)
7403.96 In reply to 7403.93
Hi Max
Just incredible !!!
There was MOI before and MOI after your development .
It's seems so simple with your job
Thanks .... and i mean , thanks from all users.
Christian
7403.97 In reply to 7403.93
Hi Max
What do you think a bout this ...
like rectangle tool but with 2 erased lines ... then _dimensions command .
Chri
7403.98
Hi Max,
Another amazing script, thanks! Very useful indeed!
I really like christian's suggestion above, especially if the rectangle would snap to specific distances, so you can neatly place all annotations at the same distance from your drawing.
Ideally, we'd be able to set the offset from the text relative to the line, as well as the offset of the 'overshoot' of helper lines - usually you'd have this, instead of placement at very the end of these lines.
Thanks again, kind regards,
Fabien
A wonderful script Max. I think Christian & Fabien have valid ideas.
7403.100
I just created command that Show/Hide Dimensions. It toggles visibility of dimensions.
If all dimensions are hidden they will be shown else they will be hidden.
Command - Styles_ShowHideDimensions
Download it here:
http://bit.ly/1SCvfJP
Also in archive there is modified original dimension script.
It will unhide all Dimensions if they was hidden when you run command.
Max if you want you can keep this modification in future releases there is function at the end of _Dimensions.htm called ShowDimensions().
www.samardac.com
Does it possible to have something (or a trick) for have number of decimals wished?
Because edit the "round" function of the _Dimensions.htm manually is some painful ! ;)
Here you must change the "2" with number of decimals wished!
angle = round arc.angle, 2)
fixedDist:round(dist, 2);
fixedDist = round(R, 2);
7403.102 In reply to 7403.101
A little study and learning shows:
Line 21 of the .htm file has the round function, which rounds the val number to p decimals.
The function is called from 3 locations, line 52, 152, and 156, where p = 2, or p=2, or for angles, p=1.
I inserted the hard code "p+=2;" in Line 21, which raises decimals to 4, or 4, or for angles, 3decimals.
Test modification of line 21 of .htm file: function round(val, p) { p+=2; return Math.round(val*Math.pow(10, p))/Math.pow(10,p) }
I believe another user input could be added, for the desired decimals. But should 3 different user inputs be added, including one for angles?
Maybe 3 default values would be needed too?
I am not going to mess with Max's superb code :-)
7403.103
:) Ok, boss
7403.104 In reply to 7403.103
>> :) Ok, boss
You rocks!
French Version : http://moiscript.weebly.com/cotations.html
PS Here 10...
Seems 14 is the Maximum possible! So suffucient I presume! :)
So maybe you can change the 4 in 14! (line 282) ;)
EDITED: 14 Sep 2015 by PILOU
7403.105 In reply to 7403.104
No-no-no. :)
In fact nobody uses more than 2 digits after decimal point.
7403.106 In reply to 7403.105
@Max (imum)
You don't know perversity of some geometric's maniacs! :D
So my version will be customized with funny thing max="14" (line 282) :D
And for Type 4 & 5 with CTRL seems we must make this! (THX Chri)
if ( arrowType.value == 4 || arrowType.value == 5 ) { f = moi.VectorMath.createPoint (c.x+dx, c.y+dy, c.z+dz ); fixedDist = round(R, 2); }
by
if ( arrowType.value == 4 || arrowType.value == 5 ) { f = moi.VectorMath.createPoint (c.x+dx, c.y+dy, c.z+dz ); fixedDist = round(R, decimals.value); }
Ps I don't know if all that work for Imperial ? Never used, too complex for me! :(
Show messages:  1-7  …  28-47  48-67  68-87  88-107  108-127  128-138
