Dimension tool (as in sketchup)
 1-19  …  40-59  60-79  80-99  100-119  120-138
7403.80 In reply to 7403.79
May be ...
text instead of code
Chri
7403.81
While this is a very well written and useful script for now, I really hope there will be a real dimension element in the future, something that when exported in dxf can be recognized by other software (such as rhino or AutoCAD). This one is a really good idea about the approach it could have, I like the "what you see is what you get".
M.
7403.82 In reply to 7403.81
7403.81
M.
Hi wastzzz
I agree with you .
You can also note that actualy , measurement is also not interactive with drawing change ...
but this script of Max is already a magnificent improvement !
Best regards
Chri from france
And if you want an another Scale Cursor number ! ;)
From here http://moi3d.com/forum/index.php?webtag=MOI&msg=7492.4
<< you can edit the .htm file and change the range values for the slider to make it permamently go between 0 and 20 or similar.
Open the file in a text editor and find the moi:Slider element in there, the ranges are set by the values min="" mid="" and max="" or similar.
If you set them to min="0.0" mid="100.0" max="20.0" then your slider will go between 0 and 20.
EDITED: 12 Jul 2015 by PILOU
7403.84
v.0.97
Select line/curve/edge and then run the script ;)
EDITED: 7 Mar 2022 by SMIRNOV
7403.85 In reply to 7403.84
Seems terrific! Bravo! :)
Works like a charm!
And with your _patternselection we can make some Dash curves! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6518.11
maybe an automatic dashed Lines / Curves dimensions ?
French Version http://moiscript.weebly.com/cotations.html
7403.86 In reply to 7403.78
Hi Max,
>unfortunatelly your last changes broke type 5 in the circular mode.
May I kindly ask you what do you mean? It seems to me that type 5 works in same way in version 0.94 as well as 0.95. I noticed only that the type 5 works a bit different in non circular mode in comparison to circular mode - second click cannot be done in centre of radius, but if the second click is done inside of circle the dimension is correct. The last change is concerning only dimension line length and Scale range, because I didn't like uselessly long dimension line with large radius.
Regarding numeration... I have absolute zero experiences with script writing as I mentioned in some of my previous post; therefore numeration is new for me as well. I've tried only adjust your script for my usage only and because I wanted to share it here in the forum I used continuing numeration in order to differentiate my interference. Sorry for my unfamiliarity with that, but if you mean that such adjusting doesn't correspond to your concept please correct it or delete it, because I have no ambition to use any my identification in your script. I wouldn't take the liberty of doing this at all, because I strongly respect for your work :-)
Kind regards,
Mik
EDITED: 12 Jul 2015 by MIKULAS
7403.87 In reply to 7403.86
Hi Max,
I know already what you meant :-)
The misunderstanding was based on my "BC" usage of type 4 and 5. I used for outer radius type 5, but in circular mode it make sense to use type 4 now, exactly as Chri posted in 7403.75.
var "BC" = "before circular mode" :-)
Mik
7403.88 In reply to 7403.84
hi Max
in french : BRAVO monsieur SMIRNOV , vous etes un grand monsieur !
Many thanks MAX , you are great ! - Максим, спасибо
Chri
EDITED: 9 Jan 2021 by CHRI
7403.89 In reply to 7403.88
7403.90 In reply to 7403.89
7403.91 In reply to 7403.90
That is just awesome!! Thank you Max!
7403.92 In reply to 7403.90
EDITED: 29 May 2020 by CHRI
7403.93
Release candidate ;) v.99
Added:
Feet/Inches format
Angles > 180
Type names
Type 6 activates circular mode automatically
Near perfection! ;)
7403.96 In reply to 7403.93
Hi Max
Just incredible !!!
There was MOI before and MOI after your development .
It's seems so simple with your job
Thanks .... and i mean , thanks from all users.
Christian
7403.97 In reply to 7403.93
Hi Max
What do you think a bout this ...
like rectangle tool but with 2 erased lines ... then _dimensions command .
Chri
7403.98
Hi Max,
Another amazing script, thanks! Very useful indeed!
I really like christian's suggestion above, especially if the rectangle would snap to specific distances, so you can neatly place all annotations at the same distance from your drawing.
Ideally, we'd be able to set the offset from the text relative to the line, as well as the offset of the 'overshoot' of helper lines - usually you'd have this, instead of placement at very the end of these lines.
Thanks again, kind regards,
Fabien
A wonderful script Max. I think Christian & Fabien have valid ideas.
Show messages:  1-19  20-39  40-59  60-79  80-99  100-119  120-138
