Dimension tool (as in sketchup)
 1  …  22-41  42-61  62-81  82-101  102-121  122-138
7403.62 In reply to 7403.55
it is better to turn outside the circle , explanation on the next POST :
il est préférable de tourner en dehors du cercle, explication dans le prochain POST:
Chri
EDITED: 6 Jul 2015 by CHRI
7403.63 In reply to 7403.62
7403.64
v.0.9a (fixed: division by zero bug)
This will be in the next version. Of course there will be degrees instead of cm.
EDITED: 7 Mar 2022 by SMIRNOV
7403.65
wastzzz
replace line: arrow = concat ( factory ('planarsrf', arrow), text);
with: arrow = concat (arrow, text);
christian
Pilou wrote about this problem. It has been fixed.
7403.66 In reply to 7403.64
<< Of course there will be degrees instead of cm.
And also i suppose any text you want? (with the help of "|" and "*") ;)
7403.67 In reply to 7403.66
Pilou, yes.
Another little thing! :)
When you increase the line ( with your option Concat above) you can have some cool forms!
But the position of text is not following! (sure I can move it in a second but when you have 100 dimensions... ;)
Can we have an enter Box of distance text or similar ? (text can be inside or outside in this last case )
7403.69
7403.70 In reply to 7403.69
Cool but how it's work ? :)
I see a new Type 6 but...
7403.71 In reply to 7403.70
Use Arrow type 6 and press the CTRL key whilst clicking on the corner point.
Martin.
7403.72 In reply to 7403.71
Must be another thing because that dimension length not angle! ;)
Ah I have found! You must disable Units! :)
Ps Does it be possible to dimension a curve ?
(maybe in connexion with CurveLengthBeingDrawn ?
or CurveLength?
script: /* Show CurveLengthBeingDrawn */ try { moi.ui.commandUI.setInterval( 'var crvs = moi.geometryDatabase.getObjects().getCurves(); var len = 0.0; if ( crvs.length > 0 ) { len = crvs.item(crvs.length-1).getLength(); } if ( !window["_crvdistlabel"] ) { document.body.insertAdjacentHTML( "beforeEnd", "
" ); } _crvdistlabel.innerText = len.toFixed(4);', 250 ); } catch(e) {}
script:/* Calculate length of selected curves and copy to the clipboard as text */ var crvs = moi.geometryDatabase.getSelectedObjects().getCurves(); var len = 0.0; for ( var i = 0; i < crvs.length; ++i ) len += crvs.item(i).getLength(); moi.copyTextToClipboard( len );
Something like this but with the Arrowline following the curve! :)
French version! :) http://moiscript.weebly.com/cotations.html
Pss We can't dimension an arc circle >180° !
EDITED: 10 Jul 2015 by PILOU
7403.73
Great job Max, Thanks!
-Yuan
EDITED: 9 Jul 2015 by YUAN
Size: 145 KB, Downloaded: 89 times, Dimensions: 1035x788px
7403.74
Hi Max,
angle measurements is excellent feature!
Thank you very much.
I've adjusted slightly the function of Arrow type 5. In new version the length of line is controlled by text length, see bellow please.
Old version:
New version:
I've increased the Scale value to 100 as well, because 40 was not sufficient for bigger models.
Thanks again for perfect script.
Mik
7403.75 In reply to 7403.74
Hi Mik
About length of line...
Since version 0.9.2015.07.06 you need to use the new Mode (with CTRL) with arrows 4 and 5
please take a look at the post of Max ( 4 jul 2015 )
same thing with mode 6
clic on the picture below to see my example .
Chri
EDITED: 10 Jul 2015 by CHRI
Size: 310.3 KB, Downloaded: 93 times, Dimensions: 650x404px
7403.76 In reply to 7403.75
hi
Small change in the script _Dimensions.htm to increase decimal
( SUBSTITUTE 0 BY 2 IN THE SCRIPT )
Chri
EDITED: 11 Jul 2015 by CHRI
Size: 26.8 KB, Downloaded: 119 times, Dimensions: 574x336px
Size: 27.7 KB, Downloaded: 107 times, Dimensions: 599x330px
Size: 17.8 KB, Downloaded: 95 times, Dimensions: 365x189px
7403.77
Hi Chri,
thank you for post.
Length of dimension line in my first version of Arrow type 5 was controlled by distance between "first click" and "second click". No problem with it when you use it for radius length which is larger than text length. The problem appears typically if Scale value is high and radius small, scale value 40 + radius 1 mm for instance, contrariwise with large radius (100 mm) the length of dimension line is 100 mm as well and it's uselessly long. Please see picture "Old version" in my previous post for example.
In new version you can use the maximal Scale value + minimal or large radius and the length of the line will be a bit longer than text length, exactly 2x longer than arrow length :)
Mik
7403.78 In reply to 7403.77
Hi Mik,
unfortunatelly your last changes broke type 5 in the circular mode. I can't accept it. I think it will be better if you create a fork of my script using your identification instead of continuing version numeration of my script. For example: v.0.95mik.
7403.79 In reply to 7403.78
hi MAX
Very great job !
What do you think about this new add :
by picking 3 points and use * comment , draw a comment on the last entitie of a broken line .
Chri
7403.80 In reply to 7403.79
May be ...
text instead of code
Chri
7403.81
While this is a very well written and useful script for now, I really hope there will be a real dimension element in the future, something that when exported in dxf can be recognized by other software (such as rhino or AutoCAD). This one is a really good idea about the approach it could have, I like the "what you see is what you get".
M.
Show messages:  1  2-21  22-41  42-61  62-81  82-101  102-121  122-138
