Dimension tool (as in sketchup)
 1-12  13-32  33-52  53-72  …  133-138
7403.13 In reply to 7403.12
Thanks Christian,
eric
7403.14
Script update. Fixed few bugs. Changed internal structure. Script modifications should be easier.
Frenchy Pilou
>> Must I draw them separately ?
Yes, you should draw them manually.
>>And alas we can't use the Helpers lines for align because of the second click ! :)
You can use LockConstructionLine script
var cln =0, gd = moi.geometryDatabase, cl = gd.getObjects().getConstructionLines(), cll = cl.length;
for (var i=0; i<cll; i++) if (!cl.item(i).isTemporary) cln++; if (cln == cll) { gd.removeObjects(cl) } else { cl.setProperty( "isTemporary", false ) }
Bind it to key. Draw construction lines. Run script (the lines will be locked). Run script again to delete the lines.
Hamish, Chri, phlatt5th
Thank you :)
EDITED: 7 Mar 2022 by SMIRNOV
7403.15 In reply to 7403.14
Cool!
French version Updated! :)
http://moiscript.weebly.com/cotations.html
7403.16
Max, that's fine!
This is what the Bolsheviks were dreaming! ))))
I download and run the testing. Thank you very much!
You are, as always, is a genius!
7403.17
Forget to say about hidden features.
Double click title to load default values
Double click "Scale" to reset scale.
7403.18 In reply to 7403.17
All day a nice surprise! :)
7403.19
Beautiful script, Max!
as usual... :-)
Thanks for sharing.
Mik
7403.20
Thanks a lot, Max. Its quite usefull.
7403.21 In reply to 7403.14
Hi Max ..
Does this insert into the original script and if so, where?
Or does it replace all or part of it?
thanks,
eric
7403.22 In reply to 7403.21
Maybe like this
Just put it inside the Right Columm of a new ShortCut
but write "script:" on the beginning of the line!
So
script:var cln =0, gd = moi.geometryDatabase, cl = gd.getObjects().getConstructionLines(), cll = cl.length;
Launch the Dimension Script
Call the script of persistant lines
Draw your helper lines
Draw your Dimension
Draw your Dimension
etc
ps I have no more the Button OK that is normal ?
EDITED: 29 Jun 2015 by PILOU
7403.23 In reply to 7403.5
Great job Max, thanks for making this available!
7403.24
Added new arrow types.
The type can be switched dynamicaly by pressing "1", "2", "3" keyboard keys.
7403.25
Frenchy Pilou
Yes, it's normal.
eric
No, it's a separate script, which can be useful with Dimensions script.
As Pilou said above, you can bind it to keyboard button.
Michael
Thank you :)
Could you help me? I have problem with pointpicker snapping. Is there a way to exclude all objects with "Dimensions" style from the object snapping list?
Alt + 0216 = Ø ;)
When I draw something on a surface in the 3D view
dimension Text, arraws are not parallal to this surface!
I must draw inside the View Face!
7403.27 In reply to 7403.25
Hi Max,
You can do that by making a pass through those objects before using the pointpicker, and turn off the "hit test" flag on each of those objects using: obj.setHitTest( false );
If an object is set with the "no hit test" flag, it should cause the pointpicker to skip over it and not target any snaps on it, and also it won't be targeted for selection either. Then if you want it to behave normally later on afterwards you'll need to set obj.setHitTest( true ); on those same objects to reset it.
If you do not have the objects already separated out somehow, you can find the style index of the "Dimensions" style by using:
var style = moi.geometryDatabase.findStyle( 'Dimensions', false /*CreateIfNotFound*/ );
if ( style )
    var index = style.index;
     // Now look for objects that have obj.styleIndex == index
Hope that does what you need!
7403.28 In reply to 7403.22
Thank you Frenchy ..
eric
7403.29
Hi Max,
arrow type is nice feature.
...as Frenchy imply, it would be very useful to have two additional checkboxes (same as Unit) "prefix" and "suffix" with text field for pasting symbols or additional text in front and behind of dimensions.
... and Arc drawing with angle value would be absolutely fantastic :-)
Excellent job, thank you.
Mik
7403.30
A well made script. Quite useful while we wait for a proper dimension element.
M.
Someone ask text before the dimension, also text in replacement of the dimension! (here text is after)
You can make that but...
EDITED: 30 Jun 2015 by PILOU
7403.32
Michael
Yes! That's exactly what I needed. Thank you! :)
Mik
I've made some changes in the new version ;)
v0.6
Snapping disabled for dimension lines (now script works exacly as planned)
Added more hidden features:
Prefix can be setted by using split symbol | in the units field. Example: R|mm -> R 15.1 mm
Special for you. :) Add * in the beginning. Example: *3/4 de pieds d'alouette!
Show messages:  1-12  13-32  33-52  53-72  73-92  …  133-138
