Unwrap surface / fill surface array
All  1-3  4-5
7399.4 In reply to 7399.3
Hi Michael
Thanks a lot for your advice, I will try some of your solutions
I will post a 3dm file if I still struggle with the model,
The model is a jewelry with curved face and I need to fill surface with gems by array command without using arraygem command because it has some sort of a cone curved surface, a bit hard to explain and I might need to post a 3dm file :)
7399.5
Hello,
Evolute makes D.LOFT, might be worth a try if you are using developable surfaces regularly.
http://www.evolute.at/software-en/evolutetools-for-rhino
Show messages: All  1-3  4-5
