Need Help Importing from Solidworks
All  1-4  5-12
7396.5 In reply to 7396.4
I'm not sure an entirely new and different "cloud-based" application is really my ultimate goal, for what is essentially a request for information about optimizing the export of STEP files.
7396.6 In reply to 7396.5
Just with it you have nothing special to do with the SolidWorks format !
And then export in Step format to Moi! What do want more simple ?
That's all! No need to learn ONshape: just 2 clicks! It's just a gobetween! :)
<< Onshape can read native CAD (SolidWorks, Pro/ENGINEER, CATIA, NX, DWG, etc) and neutral CAD formats (IGES, SAT, STEP, ACIS, JT, Parasolid, DXF etc). Furthermore, Onshape’s unique multi-CAD capabilities store the original native CAD data as well as the Onshape translation. It all gets versioned, shared, and is available for download.
7396.7 In reply to 7396.1
Hi Sneather,
I was puzzled by this post since I come from a CAD Engineering background and haven't heard of such an issue with translations, especially these days . I had a quick look at this and had no issue importing a STEP file assembly from Solidworks 2011 with all part names and styles(colours) used in Solidworks, see attached.
The only thing I can think of is if your client is using SW correctly, what I mean is you can model all parts of an assembly in a single model window/session, the industry standard for SW is to model each piece as an individual part file (*.SLDPRT) then you create an assembly file (*.SLDASM) and bring in the individual part files to create the assembly.
The only way I can check is I'd need the original SW file to see what's going on, if you like you can PM me and we can organise it.
Please note the object names are different it's just that they begin with the same 3 words, I think Michael was looking into expanding long object names on mouse over, isn't that right Michael ;)
*Model from GrabCad*
7396.8 In reply to 7396.7
I gave it a whirl since I use SW2015 Pro and MoI. I had no issues exporting from SW in STEP 203 format and having the part names travel along. I see the same kind of results Danny shows. As for SW STEP Export options, there are not a lot of them. The difference between 204 and 204 is that 204 loads styles, 203 does not.
_________________________
Don Cheke
Visit: Textual Creations
7396.9 In reply to 7396.8
If you want to post one of the step files they have sent you I can check it out.
Don Cheke
7396.10 In reply to 7396.7
DannyT,
Thank you for the help!
I'll consult with the CAD designer to see whether they are working as you outlined.
7396.11 In reply to 7396.9
Don,
Thank you for your offer, and for your prior post as well!
I'll have to ask the client whether they will be okay with me posting any of their work. But I'll let you know.
Cheers!
7396.12 In reply to 7396.11
If you prefer, you can always email it to me and I will keep it confidential. I work with confidential client files all day every day so know the importance of that.
dcheke@sasktel.net
Don Cheke
Show messages: All  1-4  5-12
