Separating many objects?
All  1-3  4-6
7392.4 In reply to 7392.3
Hi sneather,
> Oddly, I can't get the script to do anything. I pasted the script in to my "Shortcuts" menu,
> but it doesn't do what I was hoping.
Hmm, I just tested it over here and it seems to work ok for me - did you select the objects you wanted to have names assigned before running the script?
The script should work on selected objects and any unnamed selected objects unique object names like object_0001, object_0002, etc...
> I'd like to attach part of the problem model, but the compressed file is still 12-megs. How may I post that here?
You'll need to use a file sharing service like DropBox or Microsoft OneDrive that can host your large file and then you can post a link to it here, or send me the link through e-mail if you want to keep it private.
7392.5 In reply to 7392.4
Yes, I was careful to select my objects before running the script. it's totally possible that it's not even the right solution for what I'm selecting, so who knows? That's why I want to have you take a quick look at the project file. I'll post it with my YouSendIt account, and email you that link.
Thanks so much!
7392.6 In reply to 7392.5
Hi sneather, I just sent you an e-mail as well, but the reason why the script is not working for you is it only assigns names to currently unnamed objects, and your file has nearly all the objects assigned to one name in it already. If you clear the object names from everything then the script should work for you.
To clear object names, select the objects and then click on the name line in the properties panel (the one labeled #1 here: http://moi3d.com/3.0/docs/moi_command_reference11.htm#propertiespanel) and delete any text in the dialog that pops up and push OK.
Show messages: All  1-3  4-6
