Easiest way to terminate a sweep?
All  1-7  8-20
Excellent! French version ;) http://moiscript.weebly.com/blendcap.html
EDITED: 5 May 2015 by PILOU
Don't work with a multiple selection ?
7370.10 In reply to 7370.9
Sorry no it doesn't - that's mostly because Blend itself is not set up to work with multiple different blend surfaces at the same time.
BlendCap applied twice to a narrow spherical elastica ribbon, then Blend them, delete ribbon, join to solid.
A curiousity about the "Blend Cap"
Curiously we can't make Top BlendCap then Bottom BlendCap on the same object "thin wall without caps " !
We are obliged to move it for success!
Does this normal ?
PS Found a trick : Union result of the Top BlenCap then Bottom BlandCap will work! but curious anyway! :)
EDITED: 22 Dec 2020 by PILOU
7370.13 In reply to 7370.12
Humm
I've tested and i can make the both on the same
EDITED: 31 Dec 2020 by FINEMA
7370.14 In reply to 7370.12
Hi Pilou, do you have an example 3DM file you can post?
7370.15 In reply to 7370.14
Any drawing of a planar closed curve don't work at home for me! :)
V4 last december 21 :) idem for previous V4 october!
Idem for V3
I draw a simple curve closed then extrude it without cap!
Idem for no planar closed curve!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/curiosity_blencap.3dm
I test it and it's ok.
But you can't do a right-click to do the second blendcap.
You have to call the blendcap.
I see the blendcap cut the closed edge to do 2 edges.
I think Blendcap cut the closed edge then do a blending. Right Michael ?
7370.17 In reply to 7370.16
Philou
test with your file and it's OK for me...
7370.18 In reply to 7370.16
Aaaaaaah yes the Right Click don't works! ( I am fan of the Right Click! )
The normal recall function works!
So maybe that will be improved! :)
7370.19 In reply to 7370.18
Yeah the way it happens to work is it splits the edge and then it runs the Blend command. So if you right-click the system thinks the last run command is Blend and re-runs that instead of re-running BlendCap.
I guess the way to improve this would be to be able to pass in an option for moi.command.execCommand() to tell it not to record that one as the last run command.
7370.20 In reply to 7370.19
...out of my competence! :)
Show messages: All  1-7  8-20
