Fixing Problems in model/learning
All  1-5  6-13
7364.6
Thanks everyone for the input. I did rebuild it from scratch and it looks great (tho I'll go back to the other one for some practice). One question, does it matter if you take a solid and cut everything from it vs drawing a closed curve outline and extruding it to a solid and then cutting from it?
Also with Trim, how does it know what direction to take the cutting plane from?
Scott
7364.7 In reply to 7364.6
Hi Scott,
It doesn't really matter how you make the base solid, a solid extruded from a closed curve is just as much a solid as any other way... I'm not exactly sure what other method of creating the solid you are asking about for comparison with extrude though...
If the cutting object in Trim is a planar curve, it uses the normal of that curve's plane as the projection direction.
Hope this helps!
7364.8
Hello,
I've uploaded one method to make the part from the reference. Comments and critiques are welcome.
Part Creation From Reference
https://vimeo.com/125976976
Cool re-engeneering!
7364.10 In reply to 7364.8
Thanks so much for producing that. It's great to watch over someones's shoulder as you did. I learned a lot.
Scott
7364.11
Hello,
I finished off the back part of the model since there were a few more commands in MoI that could be useful in the part creation process.
https://vimeo.com/126180724
Very clear explanation!
7364.13
Hello Pilou,
Thank you for the compliments, now if only I could distill it down to a few minutes.
Show messages: All  1-5  6-13
