drawing the foot in the pod tutorial
All  1-6  7-9
7332.7 In reply to 7332.6
it is for a mold.
David
www.hooksolutions.com
7332.8 In reply to 7332.6
hey thanks for the help.
David
David -
I'm not the machining expert here, but I think Rail Revolve is going to give you the simplest geometry.
1) Draw profile curve. 2) Rail Revolve. 3) Boolean diff with straight line. 4) Fillet to create rounded bottom edges.
The trick to prevent the pinching shown in your example is to insure the end points of the profile curve are tangent. If you want to be sure, Show Points, select a pair of points, and use the Horizontal Alignment tool to line them up as shown in red. File is attached.
Show messages: All  1-6  7-9
