Hi Hamish,
> The screen captures you posted aren't from that location are they?
Nope, they're just from the regular dialog that pops up on save.
But the options that I showed before will only be displayed if you are doing a hidden line drawing generation by exporting solids and surfaces as part of the PDF export, if you are exporting only wireframe curves alone those options won't show up.
There is not currently any way to modify the line thickness for a wireframe curve export, that's set to only use a width of 1.0, with colors and layers coming from style assignments.
