Need help that MoI meets Z88
 1-13  14-33  34-38
How load a file inside Z88 ? :)
I suppose it works only with DXF format ?
PS You don't like this free one ? :)
http://geuz.org/gmsh/ reload IGES, Step from moi ;)
http://geuz.org/gmsh/screencasts/
+ http://www.calculix.de/
or even Salome + Netgen http://www.salome-platform.org/ + http://www.hpfem.jku.at/netgen/index.html
EDITED: 4 Apr 2015 by PILOU
7323.15
Hi Max and all.
Here is the example of z88i1.txt.
It is the input file of the "Kranträger".
Pilou: In the past I allways worked with the open source version Z88 10.
Please copy the file in the main folder.
To work with Z88 is not a simple process. Max´s script will make it much more easy.
Z88 I like because it calculate the forces between the knots. Most importend if we build a "new Eiffel Tower" is
to construct the struts resistant against the bending loads. (Euler cases)
Colourfull pictures of "von Mises tension" do not help. Under load a frame structure will be destroyed when the
struts bend out.
Please stay patient. We will see what a powerfull tool MoI is not only in design also in development and engeneering.
Happy and optimistic Eastertime
Hans
7323.16 In reply to 7323.15
Thx: take your time we will be very patient! ;)
7323.17 In reply to 7323.15
NOTE: I should have opened the Informationen file in a proper word processor. :-( It comes pre-parsed.
I did a Parse of the Kranträger file in an attempt to understand it, and reconcile it with theoryguidePDF.
A few differences and questions resulted.
// Header is the first group, and has seven entries. (Versus 5 ???)
// #Dimensions = 3
// #Knots (or #Nodes) = 26
// #Struts (or #Elements) = 72
// DegreesOfFreedom = 60 (3 times 26 = 78, not 60 ???) (Maybe because structure is open, not closed?)
// LawOfE-modulus (What is this?)
// Flag (KFLAG is 0 for cartesian coordinates)
// Flag (Why are there two flags?)
3 26 72 60 1 0 0
// The second group has entries for each of the 26 KnotNodes.
// Knot#, DegreesFreedomThisNnot, Xcoord, Ycoord, Zcoord.
1 3 20 20 0
2 3 0 0 0
3 3 10 10 25
4 3 0 20 0
5 3 20 0 0
6 3 30 10 25
7 3 40 20 0
8 3 40 0 0
9 3 50 10 25
10 3 60 20 0
11 3 60 0 0
12 3 70 10 25
13 3 80 20 0
14 3 80 0 0
15 3 90 10 25
16 3 100 20 0
17 3 100 0 0
18 3 110 10 25
19 3 120 20 0
20 3 120 0 0
21 3 130 10 25
22 3 140 20 0
23 3 140 0 0
24 3 150 10 25
25 3 160 20 0
26 3 160 0 0
// The third group is explained on page 55 of theoryguidePDF.
// not sure if this is the correct parse.
1 4
1 2
2 4
3 2
3 4
3 4
4 4
3 1
etcetera (Did not parse the rest of the file)
EDITED: 24 Oct 2015 by BEMFARMER
7323.18
Hi Hans
Check the new version.
At the moment it supports 3D knots only.
I have the same question about DegreesOfFreedom. Why 60?
EDITED: 7 Mar 2022 by SMIRNOV
If the first 3 nodes, and the last 3 nodes are fixed, or boundary condition, maybe they do not count?
3 X (26 - 6) = 60.
(There is so much I do not know about FEA :-)
There is supposed to be a book...
7323.20
Hi at all.
Sorry, my mistake.
26 x 3 = 78
I had a handbook with an example beside and wrote the wrong number.
bemfarmer:
Z88 take about 24 different type of elements. Some need special flags - some not.
For my structures I used only Type 4 and Type 9.
As a user I have no clue wy it has to be a 0. It´s inside the programm.
E-law - is the direkt translation of "E-Gesetz".
It is the same as E-Modulus.
Max: Thank you. I write a little bit later again.
Hans
7323.21
Hi Max,
for 3D- framestructures the script is PERFEKT !!!!
Thank you !!!!
At home I have some drawings of antik aircrafts.
There will be a funny example for a tutorial.
Now I go to choose one of it.
Next info at tuesday evening.
Hans
7323.22 In reply to 7323.21
Hi Hans
nice to hear it. :)
Please share the results. That interests me very much.
If everything works good, I'll make interface and 2D support next week.
7323.23
Hi Max.
Today I prepaired a structure of an old little racing biplane.
There are some pictures to scan.
Tomorrow in the evening after work we start with the first part of the tutorial.
Bye and thank you again.
Hans
7323.24
Hi Hans and Max,
Max, I'm really pleased you ended up writing this script in its entirety. You've achieved much more, and most likely better quality code, than I ever could have in the same time. Additionally, all us novice script writers get another fine example to reference - THANK YOU! :)
Hans, I really look forward to following your FEA tutorials and generally learning more about FEA. I'll inform the UK Light Aircraft Association, (the CAA delegated authority for amateur-built aircraft in the UK) engineering department after you post your first tutorial. I'm sure the LAA chief engineer will be very interested in this, certainly as an educational tool and hopefully as a useful tool for aircraft design analysis.
Cheers,
Hamish
7323.25
Hi Max, Hamish and all.
Here we start with the first part of my little tutorial.
Pilou: you asked for more passenger places. Hope you like the little plane made by a friend from Chatteau Briand airfield.
You remember? " 4 people and an basket full of eggs"
The little Biplane Racer construction now has an age of 90 years and shut been full reconstructed.
Attention please!!!!
The example of workflow we will see in the next days is not for practical use. All loads that will be setted are "over the thumb" calculated
to save a lot of time.
The MoI files show how to draw a structure and and the racer structure we only need to place the loads for the fuselage.
Z88i1.txt was made in five seconds. The true lengths of all struts have been saved in an other file for later using.
We see a picture of the structure opened in Z88 with all node numbers. Now we have to prepaire the z88i2.txt files
to calculate step by step all loads. It needs a little time and I can do this over the next days.
Next time we see how to make a load file and to build a data structure with Excel.
Hans
Size: 242.1 KB, Downloaded: 42 times, Dimensions: 1280x1024px
7323.26
Hi Hans,
This looks like it should develop into a very useful tutorial: complex enough to prove the value of using a tool like z88, but not so mind-blowingly complex that it puts people off learning more about structural analysis. Thank you so much - I know it takes some time to prepare these kind of lessons. I look forward to reading the next step!
You say the preparation of z88i2.txt will take some time. Perhaps not on this occasion, but is the preparation process something that could also benefit from being automated by way of a text-editing script?
- Hamish
The Louis Blériot's plane ;)
7323.28
Hi Hamish.
To create a loadfile is a process that must be done manualy step by step.
Description follows.
Hans
7323.29
Hi at all.
I´m sitting in my classroom, my students are working and there is a little bit time
to explaine the z88i2.txt file to handle the loads.
The file consist of more ore less textlines with numbers.
every line of numbers is a subcase named in german: RBD = Randbedingung
9 < there is only one number in this line to count the RBD>
Now we fix a node:
5 1 2 0
5 < number of node>
1 < x-axis>
2 < way>
0 < no movement>
5 2 2 0 < the same as above in y-axis>
5 3 2 0 < z-axis>
If we set a way like 5 2 2 8 then we will have loads in the strukture.
We fix an other node:
9 1 2 0
9 2 2 0
9 3 2 0
We put a load at node number 18 in negativ direction
18 3 1 -8500
18 < number of node>
3 < z-axis>
1 < we have a load>
8500 < if take the positiv direction>
The third node may slide in x-axis because that the structure will bend.
It is only fixed in 2 axis.
27 2 2 0
27 3 2 0
It is importend that the RBD follows the numbers of the nodes.
123458 is o.k.
128534 is not o.k.
The result is now.
9
5 1 2 0
5 2 2 0
5 3 2 0
9 1 2 0
9 2 2 0
9 3 2 0
18 3 1 -8500
27 2 2 0
27 3 2 0
z88i2.txt we save in the main folder together with z88i1.txt and run the calculation.
Now we start our "over the thumb" calculation for the loads and searching the right nodes to set it in the rigth
directions.
Bye for now
Hans
7323.30
Hi Hans,
I see why it takes some time to generate z88i2.txt. I still wonder if an interactive script might be useful for creating z88i2.txt?
I envisage this second script would either step through the nodes saved to z88i1.txt - or original script is modified to generate z88i1.txt and z88i2.txt concurrently - and allow the user to enter Randbedingung (RBD) [English = constraint] conditions via a GUI.
Ideally the script would highlight the node for which RBD info is required to be entered. It might need a fwd/back/select-node interface in case the user enters incorrect RBD and wants to correct/modify it after the script has stepped to the next node.
Sometimes it's nice to have a helper script, though other times they can be more hindrance than assistance, so I fully understand if you say my envisaged second script would be less than helpful - or simply too much work. What do you think Hans, Max?
- Hamish
7323.31 In reply to 7323.30
Hello to all,
very interesting thread and work! By the way - Randbedingung - typically Boundary condition:-)(Forces, pressure, fixtures, constraint displacements ....)
A nice day to all
Karsten
p.s.: pilou - the pilot has a french curve;-)
7323.32
Hi Hamish, Karsten and all.
Hamish: this weekend I will prepaire all loads. Then we see much bigger z88i2.txt files. May be this helps you to decide
you like it or not to make a special skript for the loadfiles.
Helpfull woud be if the nodenumbers are visibel in MoI. In MoI they are more easy to select.
An other problem is my bad english. Now I visited "LEO" in the net. Some therms will be more exact in the future.
If you ore somebody else like to translate my lyrics for better reading feel free to do it like you want.
Karsten: Thank you for your positive response.
Happy days
Hans
7323.33
Today I was trouble shooting.
Max >
There is a filechecker in Z88. Something was wrong with z88i1.txt.
In my old handbook where in line 1: two flags with 0
Now it should be: three flags with 0.
Please don´t ask me why.
Sorry Max!
Hamish >
Next problem was with z88i2.txt.
Not only the nodes has to follow 1234. Also the boundary conditions
has to follow xyz.
For example:
50 3 1 4000
50 1 1 -2500
this is wrong
shut be
50 1 1 -2500
50 3 1 4000
Then z88 tells me that my structure is not corect with its static.
Could not find my mistace. It needs to much time for searching
so I will make tomorrow a more simple construktion where I can
test my 28 condition file and more with.
Good news are that with Max´s script we are also able to use the
two types of bar. Number 2 and 13.
Calculating of straigth spars are possible with it.
Helpfull for this would be a script that gives the moment of inertia from cross sections.
In MoI we draw a face. Some cad systems has it.
One year ago somebody from the Uni Bayreuth told me the make a new software that handle the other direction
of FEM. You set the load and the anotations and the software forms the part.
I believe it will be also freeware.
Bye till tomorrow
Hans
Show messages:  1-13  14-33  34-38
