Confusing ... Forum & Current Version
 1-13  14-33  34-40
7321.14 In reply to 7321.13
Hi Mauro, basically since MoI is not itself designed to run on a smartphone it's also not really a priority to focus on optimizing the support forum for it for smartphones either...
It still works to view it on a smartphone, I do it myself occasionally you just have to do some zoom in/zoom out and panning when there are large images.
There is some support in the forum software for resizing images, but I disabled it early on for some reason which I can't specifically remember right now, maybe it did not work all that great. Maybe it could be possible for me to fix that up and re-enable that in the future though.
But I've examined what is involved in making a "responsive" site and came to the conclusion that it was just too much effort involved for me to pursue it, it's something that's great to do for people where the entire thing that they are working on is a web app. But for me the web site is a support thing, my main focus is on developing the desktop software and not on spending all my time just working on maintaining a super fancy web site.
I need the web site to be simple and easy to maintain, and having something that has totally different behavior on different devices is fundamentally a complex thing to test and deal with, it's the opposite of simple and easy to maintain.
But something more limited like enabling the image resizing just on mobile might be possible at some point.
7321.15
I love the ease of accessing new posts. Other forums that I use are much more cumbersome in this regard.
However I sometimes have difficulty in tracking down particular topics that I've half remembered and a more structured forum would make this a bit easier.
7321.16
Hello,
I think the process of site and proper messaging is not nearly as trivial as some are thinking. It's certainly not a process of a few days to get it right. I'd like to see the messaging and delivery polished before anything with the forum is worked out. The forum works for now, updating it will not typically attract new customers. Articulating your benefits in an effective way to the correct audience spurs sales, which is a good thing.
7321.17 In reply to 7321.15
Hi Mike,
Unfortunately these things tend to be pretty much at odds with one another - if you impose some kind of folder structure on a forum it has a substantial fragmenting effect and it becomes difficult to get in and easily see all the new questions. You might have to do something like go in to every separate folder - instead of one place to check there can now be dozens of places.
It also becomes less friendly for new users for posting as well, they have to figure out where in the structure their new message should fit, and if they make a mistake there is some administration overhead of moving things around. These are problems that are eliminated by the current forum structure.
On the other hand, structure can be good for browsing through old messages.
I think a good compromise could be to have a concept of "tags" and that a post could have tags assigned to it and there would be some way to view things marked with a particular tag. Unfortunately the current forum does not have that concept built into it and so it would need some extensive customization in order to provide that. That will take a fair amount of time to work on and so probably won't happen anytime too soon.
There is the possibility in this forum software to have a folder organization, but it's something that I had intentionally disabled early on so as to avoid that fragmentation problem. It could be possible to have some different folders at some point though, but it's not clear to me what they would be, I would only want to have a small number of them probably.
7321.18 In reply to 7321.10
Why not buying a template?
http://themeforest.net/item/alive-responsive-bootstrap-html5-app-landing-page/10397657
http://themeforest.net/search?utf8=✓&term=app&view=list&sort=&date=&price_min=&price_max=&sales=&rating_min=&platform=
I for example use MoI mainly for conversion from CAD to OBJ for rendering.
The reasons are obvious. Without MoI most of this pictures will not exist.
https://www.flickr.com/photos/voto1979/sets/72157650107273721/
I am sure your customers will surprise you with interesting things for your homepage.
7321.19 In reply to 7321.17
Michael you should take a look at https://discourse.org I think it may fit the bill...
Some examples of their platform in use.
https://discuss.atom.io (GitHub)
https://twittercommunity.com
http://forums.sketchup.com
http://discourse.mcneel.com
7321.20 In reply to 7321.18
Hi voto1979,
I looked into that a bit, but often times the templates are rather complex and can tend to be difficult to modify and maintain.
It tends to be easier for long term maintenance to just develop the full web site yourself.
The first links you show use the Bootstrap system which I looked into some, but it was complicated enough that I decided it would take too much effort to learn it properly so that I could do a proper job of maintenance and making new pages later on.
The part that is particularly bad about a complex system that has a lot of pieces to learn is at some point in the future when I need to create a new page for some reason, if the system used to set things up is particularly complex and I haven't been directly messing with it for a while that creates a barrier at that future time.
This would not be a problem if I was only focused on web development, but that's not what I do - the web site development aspect is very much a small part of my work and not something that I'm tweaking or working with every day and that makes me all the more hesitant to use complex systems to set it up.
Anyway I've already got a new design worked out, I posted it above in case you missed it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7321.10
Yes, as you can see in the above previous message I've already collected several interesting model screenshots from PaQ to showcase on the new page.
7321.21 In reply to 7321.19
Hi adamio,
Yeah I've looked into it and it's pretty interesting but it does not cover the requirement that I mentioned above to be able to have a topics list that stays visible on the left side while having the thread contents displayed to the right of it. That's what I consider a fundamental needed feature.
Or do you know if it's possible to configure that way? None of the links that you posted show that though.
7321.22 In reply to 7321.21
MoI's forum is my favorite. It's so easy to just follow "EVERY TOPIC THAT GOES BY".... There is no other forum where I do that.... It's by far the best....
Cant find something? A simple post with a question would most likely be answered within minutes. First by several users, then the developer himself.... (Kindof fostering a community)
Pictures big? My browser automatically does the resizing once the image has filled. Maybe users can note that inline'ing a 3000 px image is kindof a bummer? If you want to post some hi res image just post it somewhere else and link it. Or just don't inline it, so it opens in a new window (Which "should" handle any resizing issue)
I'd also like to add that "responsive" websites are puke. (Funny how opinions vary)........
7321.23
+1 for the Burrman. Michael has more important things to worry about IMHO. The Forum may not be flashy, but it works.
Ron
<< Cant find something? A simple post with a question would most likely be answered within minutes. First by several users, then the developer himself.
And don't forget the own "Search" button multi-criteria of the forum itself! (at the top right middle of the screen)
Works very fine! :)
7321.25 In reply to 7321.20
Hi Michael ..
I used to be on the Rhino forum regularly and in their attempt to make it more usable it ruined it for me. I very much like the simplicity of this forum so please don't change it just to make it more glitzy and complex.
The same thing applies to the UI ... I appreciate all the work that Max has done and might buy it as a plug in ... but I don't want to have it take over or complex the UI.
Yes, the home page ... your sales page could use some updating but I would bet that your sales come mostly from satisfied users raving about your product.
cheers'
eric
7321.26 In reply to 7321.23
it's one of the few occasions, where a frame-based layout actually do make sense. it might be sufficient to upgrade the forum software, beehive, to a more recent version( 0.8.2. -> 1.4.4.). they did introduce responsiveness some versions ago, so no need to change horses.
7321.27
If it ain't broke don't fix it!
I've had no issues with the forum and I've been here for a long time :)
7321.28 In reply to 7321.21
>So it's intentional that some functions that are only used by a smaller number of people are somewhat hidden rather than put into the top level command UI.
Keeping things simple sounds great.
Still too many things cannot be scripted or scripting gets tedious fast (->factories). A command line with autocomplete would be great as well.
> In the future I do want to make scripts and extensions more easily browsable...
Recently you wrote that you are checking things out...
The latest versions of QtNetwork e.g. have typed arrays and you can easily use already existing code to unzip files. Using Git you can download whole repositories as zip files and when every file has a comment on the first line you could then just copy all scripts and the describing comment to the options window.
That could be done without a lot of work on your side.
7321.29 In reply to 7321.21
Michael not sure if it could be customised that way, sorry not my area of expertise.
7321.30
I love this forum like it is. It is just a forum, and in it´s simplicity it is perfect.
7321.31
I think forum must has categories, like, News, finished Models, Wip, Discussions, Scripts, Help, e.t.c In the rest forum is ok.
7321.32
Il like the forum, one of my favorite forum layout.
Moi3d is hands down the most rewarding experience I had in my whole 2d/3d computing life.
Don't care much for fireworks when a real work of art shows up, it's so rare.
Marc
7321.33
Michael (amazingly) runs a one-man shop. He is one of the most responsive software developers going. I can't think of a single application that has a programming team that is more responsive to customer questions or desires that Michael manages to be all by himself.
I find the MoI discussion site very usable. I like how easy it is to find things and to control how it displays topics. Yes, it is bare-bones; but I wouldn't want to divert too much of Michael's valuable time into polishing it. Put me in the "ain't broke, don't fix it" camp.
Show messages:  1-13  14-33  34-40
