PDF export: result are displaced
All  1-3  4
7307.4 In reply to 7307.3
Hi Jörg, your problem probably has to do with the paper size set in the PDF file that Moi generates. Currently MoI will only generate a paper size of a US letter size (8.5 by 11 inches).
If you want to print an A4 size instead, you will need to edit the paper size in the PDF file, you can do that by opening it in a 2D vector editing program like Adobe Illustrator for example. Open it up there, change the sheet size and then the content that is currently running off the edge of the 8.5x11 inch paper size should then be visible.
Some more info in this other thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6522.1
At the bottom of the above thread is a link to a command line utility that can be used to modify the page size instead of doing it in Illustrator.
In the future I want to make it possible to set the page size as an option when you generate the PDF file. Since the PDF generation is a pretty new feature it is more oriented currently towards just generating the vectors as the main priority for now.
Show messages: All  1-3  4
