OnShape
 1-11  12-28
7302.12 In reply to 7302.8
Yes, it was symmetric. I also wondered why...
7302.13 In reply to 7302.11
Burrman is not usng Onshape. Read the docs on outputting STEP files. You have to right-click in the step file tab at the bottom after you translate the converted Onshape model to STEP. Also BE SURE and set the correct dims in both MoI and Onshape. I used mm for both.
7302.14 In reply to 7302.11
Sorry ron, didnt mean to confuse the issue. My vid is a different modeler.
7302.15 In reply to 7302.14
@ Burr
Yes this direct modeling tool DesignSpark is a killer!
Little problem seems you can't export as nurbs format with this free version! ?
So Thanks Max Smirnov for its _Import_OBJ !
Subdiv don't work with a native cylinder of Moi! ?
What we must do for that works ?
PS Byob is also this crazzy VERY FUNNY free language! :) Build Your Own Blocks! :)
http://snap.berkeley.edu/old-byob.html
Now Snap ONLINE !
EDITED: 20 Mar 2015 by PILOU
7302.16 In reply to 7302.15
The best would be if you learn and understand traditional subd modeling, prior wondering why something not works like you expect....
The model you show in the picture is also very bad and does not resemble a properly modeled subd mesh.
Hope this helps!
7302.17 In reply to 7302.16
A cylinder in Polymodeling are triangles (2 triangles = 1 quad : sometimes Ngons) primitive like shown above
The sub divided object is just the result of the previous cylinder by the Max plugins
I had personally nothing modelised here :)
I must jut refound what are the start proprieties of a volume accepted by the Max Subdive plugin :)
Quad facetts, triangles facetts...
I had believed that the Max plugin accepted and transform the nurbs volumes ! :)
7302.18
No problem, Burrman! I should never post to the forum in the middle of the night, when I should be sleeping. :-)
I understand all the posts much better today!
Ron
7302.19
I've been fooling around with OnShape. Uploaded a STEP file created in MoI and added some fillets, but how do you download a file in STP format, to reopen it in MoI? I'm using the browser version, not a mobile app.
Thanks!
7302.20 In reply to 7302.19
BOTTOM LEFT OF YOUR SCREEN :)
7302.21 In reply to 7302.20
Ah, great! Thanks!
— Metin
http://metinseven.com — pixel art • illustration • 3D (print) models • characters • icons • logos • infographics • visualization • animation
7302.22
It will certainly be great to have drafting tools inside MoI BUT until then that could be a solution for some MoI users :)
OnShape adds on Graebert’s new cloud-based CAD technology for drafting.
http://gfxspeak.com/2015/04/16/graeberts-technology-drafting/
7302.23
Thanks for the fillet orgy video BurrMan ! Wish this kind of software will be one day available for the average joe :)
7302.24 In reply to 7302.23
Yes Wak, until then, a guy can dream......
So you can use the amazing functions of Animation of Onshape! ;)
EDITED: 14 May 2022 by PILOU
7302.27 In reply to 7302.26
Handy piece of kit :)
Martin
(TpwUK)
Searching a "no organic" application on Android Tablett...Onshape works perfectly! :)
https://play.google.com/store/apps/details?id=com.onshape.app&hl=fr&gl=US
If you have another free applications "no organic" on Android don't hesitate!
PS Tinkercad seems working fine ! https://play.google.com/store/apps/details?id=com.tinkercad.www.twa&gl=FR
EDITED: 15 May 2022 by PILOU
Show messages:  1-11  12-28
