More feedback notes (modem model)
All  1-3  4-7
73.4 In reply to 73.3
Hey Michael,
-shift key thing= I personally don't mind this. That key combo is common in many packages. This is how I found out it worked in MOI.
- Rotate copy= I guess I was thinking about a multiple polar array. (5 copies @ 35deg) I used the copy option within rotate but I could only make one copy at a time.
- Grouping/boolean= OK, so in the side view I select the main body as my "base" object, then drag select all the cylinders for the second selection. Great! I didn't think about that.
- undo/hide= when I tried to undo the hide command I brought back an oject that I had previously deleted. In other words I would delete something, work a little, hide something and undo the hide, this would recall the deleted object. make sense?
- Thanks for the words on the comments. I'll keep em coming when I can and what ever happens happens!
-Dooki
73.5 In reply to 73.4
Whoops, I got confused for a moment, I actually forgot that I put that shift + right drag for panning in there.
I don't know if you've noticed, but there is an auto-scroll mechanism for pan which kicks in when you move nearby the edge of the viewport.
> re: hide
Yeah, this is the problem - hide is not recorded as an actual undoable action right now. So when you do an undo, it doesn't care about the hide, it doesn't do anything for the hide and just goes to the to the last "real" action in the undo stack - that is something that actually created, deleted, or altered geometry.
Right now hide is considered to be about the same as selection - if you select an object and then undo, it doesn't undo the selection, it undoes the last changing operation.
I'm thinking of changing this for both hide and selection, so that if you make a selection or hide mistake, you can hit undo to step back to the previous state.
73.6 In reply to 73.5
That sounds good.
Tomorrow I wil be another day and another model...
I just thought of something else. Is there a way to recall the last tool tool or action. In rhino it hitting the space bar will recall and action. Just a thought.
-Dooki
73.7 In reply to 73.6
Not currently, but this won't be hard to add.
Show messages: All  1-3  4-7
