NVil, Samardac Config 1.0
 1-4  5-24  25-44  45-64  65-76
7299.5
Yep, I'll made videos. I'll release them today or tomorow with new version of config.
Also I will release help with all shortcuts.
EDITED: 13 Mar 2015 by ANDREI SAMARDAC
7299.6
Samardac NVil Config 1.1 is availible for download.
Major changes:
Toggle SubD shortcut now is (Space)
Best Fit shortcut now is (RMB)
Other changes:
Changed some buttons also added button PANEL(F11), witch show/hide all panels.
Now HELP is available online:
http://nvil-help.tumblr.com/
This Config is THE BEST for NEW USERS!
Download:
http://bit.ly/1AkyH30
7299.7
Thanks Andrei
All those keyboard shortcuts are very useful. It is the fastest way to work once you become familiar with the program.
My only comment would be that the commands in Grow/Shrink selection are bit long. It is something you use often when poly modelling. All the other keyboard shortcuts are beautifully done being nice and short.
~Kevin~
7299.8 In reply to 7299.7
kevjon,
They looks long but when you are press them they are short and your fingers will remember them in seconds, I use them for a long time. Try them and if you will feel that it is too long after working with them, let me know, I'll think what I can change.
7299.9
Thanks Andrei,
Excellent config!
Looking forward to the videos :)
7299.10
Andrei
The inset tool is tricky to use. If you push you mouse the wrong way (out instead of in) you end up with an extra polygon.
The tool tips on all your buttons are extremely helpful to learn the software.
7299.11 In reply to 7299.10
kevjon,
It is how it should be. If you drag it to the left it will Inset Outside, if you drag it to the right it will Inset inside. There a re a lot of situation where you need to make Outside Inset.
I modified Tool Tip of Inset.
7299.12
Samardac Config 1.2 is available for download.
Updates:
Was simplified Grow/Shrink shortcuts:
1. Grow/Shrink Selection (Tab+MW)
2. Grow/Shrink Loop (Tab+Ctrl+MW)
3. Grow/Shrink Loop (Tab+Shift+MW)
4. Undo/Redo Multi - (Ctrl+Z+MW)
Some Tool Tips was Updated.
Download:
http://bit.ly/1HT0Raz
7299.13 In reply to 7299.11
Ok thanks Andrei
I was a bit confused which way you push the tool on screen to get the desired result.
Thanks for the updated config, will give that try.
~Kevin~
NVil against Wings3D ? (not the the price because it's free but for the functions )
http://www.wings3d.com/
and principally this incredible version? ManifoldLab (Wings3D is inside MLAB)
https://dl.dropboxusercontent.com/u/56147717/freely-donate.html
EDITED: 14 Mar 2015 by PILOU
7299.15 In reply to 7299.14
I used Wings 3D a long time ago and it was far behind NVil, do not know how it is now.
7299.16 In reply to 7299.15
This ManifoldLab is some funny! ;)
a little try :)
7299.17 In reply to 7299.12
Thanks Andrei, your NVil config and bridge are excellent!
7299.18
SAMARDAC NVil Config 1.3
NVil version no less then NVil-Mar-14-15 is needed.
Download it here: http://www.digitalfossils.com/Download/NVil-Mar-14-15.rar
Now there is no need to install Config by hands, just download Samardac Config, extract and run it. You will be prompted to install Samardac Config or Restore previous settings.
UPDATES:
StreamLine:
"Draw" (4) tool was added.
It crates polygons by drawing vertexes, also you can create just vertexes or add vertexes to edges(just go over edge and it will snap to it, then add vertex). You can draw on grid, Work Plane or Objects.
"Move" (W) Now if you move one vertex to another and hit (W) again it will weld them.
Snap:
Snap to Spline button was added
Snap to Plane button was added
Workplane:
lock Work Plane button was added
Splines:
Some commands was Improved.
Added button - From Edge (Create spline from selected edges)
Other:
Tool Tips now will stay as long as you need for comfortable read.
Added Shortc Cut - Cancel Command (ESC)
Other bugs fixed.
DOWNLOAD:
http://bit.ly/1Dngs3b
EDITED: 15 Mar 2015 by ANDREI SAMARDAC
7299.19
Video tutor, Samardac Config Overview.
My Portfolio: www.samardac.com
A lot of my Tutorials!
7299.20 In reply to 7299.19
Great stuff, Andrei. Looking forward to the next tutorial.
Mike.
7299.21 In reply to 7299.20
Video was a very good overview of the tools, thanks.
Look forward to seeing the next one on modelling in Nvil.
~Kevin~
7299.22
Some major UI updates was made.
User Interface:
- All UI was rebuilded and Optimized to preserve more space for viewport.
- StreamLine Panel was disbanded. Now there is only one Panel - Modeling.
- Pivot window was modified, there was added buttons Set Pivots. Also buttons in Position and Orientation was modified now if you pres RMB Position and Orientation will be synchronized.
- Create Symmetry and Enable was combined.
- Show/Hide symmetry Plane command was added , now it is RMB on Change Button in Symmetry block.
- Grid in ortho view was set to be the absolutely same like Floor grid.
- Work Plane color was changed to make it easy distinguish from floor grid.
- Grid button was modified, Now it has:
LMB: Show/Hide Grid
RMB: Show/Hide Work Plane
MMB: Toggle Grid/Work Plane
-Button Home was added onto the top Panel. It will set camera at origin.
- Object List button was added to Windows block.
- Origin - button was added to Windows block. It reset selected Objects to Origin.
- Some buttons from File block was combined.
- Some Tool tips updated
Commands:
- Primitives now can be started not only from Object mode but from any mode.
- Snap Enable/Disable (Alt+X) shortcut was added.
- Home (Sift+Rmb). Set Camera to Origin
You can watch video overview here.
Download here: http://nvil-help.tumblr.com/
EDITED: 16 Mar 2015 by ANDREI SAMARDAC
7299.23 In reply to 7299.22
Part one of Modeling tutorials in Samardac Config:
Andrei -
Thank you for taking time to make the video tutorial. Tonight I'll try making a spoon :)
Hopefully in future tutorials you'll bring a NVil model into Moi for some precision enhancements.
MoI will remain my primary program as I make mostly mechanical items. But there are situations where I need objects of an organic nature.
The fact that you can go back and forth between NVil and MoI creates some new possibilities.
Show messages:  1-4  5-24  25-44  45-64  65-76
