NVil, Samardac Config 1.0
 1-16  17-36  37-56  57-76
7299.17 In reply to 7299.12
Thanks Andrei, your NVil config and bridge are excellent!
7299.18
SAMARDAC NVil Config 1.3
NVil version no less then NVil-Mar-14-15 is needed.
Download it here: http://www.digitalfossils.com/Download/NVil-Mar-14-15.rar
Now there is no need to install Config by hands, just download Samardac Config, extract and run it. You will be prompted to install Samardac Config or Restore previous settings.
UPDATES:
StreamLine:
"Draw" (4) tool was added.
It crates polygons by drawing vertexes, also you can create just vertexes or add vertexes to edges(just go over edge and it will snap to it, then add vertex). You can draw on grid, Work Plane or Objects.
"Move" (W) Now if you move one vertex to another and hit (W) again it will weld them.
Snap:
Snap to Spline button was added
Snap to Plane button was added
Workplane:
lock Work Plane button was added
Splines:
Some commands was Improved.
Added button - From Edge (Create spline from selected edges)
Other:
Tool Tips now will stay as long as you need for comfortable read.
Added Shortc Cut - Cancel Command (ESC)
Other bugs fixed.
DOWNLOAD:
http://bit.ly/1Dngs3b
EDITED: 15 Mar 2015 by ANDREI SAMARDAC
7299.19
Video tutor, Samardac Config Overview.
My Portfolio: www.samardac.com
A lot of my Tutorials!
7299.20 In reply to 7299.19
Great stuff, Andrei. Looking forward to the next tutorial.
Mike.
7299.21 In reply to 7299.20
Video was a very good overview of the tools, thanks.
Look forward to seeing the next one on modelling in Nvil.
~Kevin~
7299.22
Some major UI updates was made.
User Interface:
- All UI was rebuilded and Optimized to preserve more space for viewport.
- StreamLine Panel was disbanded. Now there is only one Panel - Modeling.
- Pivot window was modified, there was added buttons Set Pivots. Also buttons in Position and Orientation was modified now if you pres RMB Position and Orientation will be synchronized.
- Create Symmetry and Enable was combined.
- Show/Hide symmetry Plane command was added , now it is RMB on Change Button in Symmetry block.
- Grid in ortho view was set to be the absolutely same like Floor grid.
- Work Plane color was changed to make it easy distinguish from floor grid.
- Grid button was modified, Now it has:
LMB: Show/Hide Grid
RMB: Show/Hide Work Plane
MMB: Toggle Grid/Work Plane
-Button Home was added onto the top Panel. It will set camera at origin.
- Object List button was added to Windows block.
- Origin - button was added to Windows block. It reset selected Objects to Origin.
- Some buttons from File block was combined.
- Some Tool tips updated
Commands:
- Primitives now can be started not only from Object mode but from any mode.
- Snap Enable/Disable (Alt+X) shortcut was added.
- Home (Sift+Rmb). Set Camera to Origin
You can watch video overview here.
Download here: http://nvil-help.tumblr.com/
EDITED: 16 Mar 2015 by ANDREI SAMARDAC
7299.23 In reply to 7299.22
Part one of Modeling tutorials in Samardac Config:
Andrei -
Thank you for taking time to make the video tutorial. Tonight I'll try making a spoon :)
Hopefully in future tutorials you'll bring a NVil model into Moi for some precision enhancements.
MoI will remain my primary program as I make mostly mechanical items. But there are situations where I need objects of an organic nature.
The fact that you can go back and forth between NVil and MoI creates some new possibilities.
7299.25 In reply to 7299.24
No Problem Ed, I'll made tutorial about NVil and MoI but I think not now)
Anyway, here is another portion of tutorials:
7299.26
Cool stuff Andrei! Very much appreciate your work.
7299.27
Very good videos Andrei, most educational to see how you go about it and how the Nvil tools work.
I've watched 3 of them so far.
In the third video where you cut the top of the sugar bottle, it was interesting to see that Nvil has a Soft Selection tool that works a bit like Modos falloffs.
Although I think it would of been easier to use the knife tool to make a nice straight cut.
I also noticed that you use a lot of creasing in your modelling and it works very nicely in Nvil. How do these creases export to other applications where you might want to uvmap the model or render. I would assume they get lost when converting to obj and importing into say blender, modo, c4d etc ?
~Kevin~
7299.28 In reply to 7299.27
About Knife you are right I could use knife, and cut it from Free space. But it was good opportunity to show how soft selection works :)
Unfortunately I do not know any way to export creases, I just subdivide model and export it.
7299.29
SAMARDAC NVIl Config 1.6
- Lightning and Viewport colors was rebuildeded
- Viewport rotation Pivot was changed. Now navigation in Viewport will be around center of selected object
- Spline Color was Changed.
- Spline Window was Modified. Show/Hide Button was added. Some buttons was combined.
- Measure button was added Commands block (It measure distance)
- Mods section was moved in separate window, now you can hide it. I do not use this window so I keep it hidden
- Button show/hide Material Library and Material window was added to Materials - MMB
Downlaod:
http://bit.ly/1EsJeNz
Last NVil Version:
EDITED: 17 Mar 2015 by ANDREI SAMARDAC
7299.30
Samardac Config 1.7
Download: http://nvil-help.tumblr.com/
Some tutor about 2D sketching in NVil.
7299.31
Impressive work there Andrei, for the interface.
I like that alot.
Made me think of Lightwave Interface but much simplier.
Congrats on your work.
7299.32
New version 2.0 is ready! Now it is simpler and more intuitive.
All Tool Tips was restored, a lot of tools was polished and rebuilded, all excess stuff was removed, shortcuts was optimized.
Download:
http://bit.ly/1CKerLM
Use not less then this version:
http://www.digitalfossils.com/Download/NVil-Apr-07-15.rar
EDITED: 6 Apr 2015 by ANDREI SAMARDAC
7299.33 In reply to 7299.32
Cool! Thanks Andrei.
7299.34 In reply to 7299.32
As a complete subd novice I'm finding NVIL rather overwhelming even with the great benefit of your configuration. I'm tripping over the simplest things. For example it took me a while to realise that your spoon tutorial is set in a different world orientation than the default. I suspect that I'm also having difficulty with some of the other basic global settings in your tutorial differing from the defaults.
I've decided to try Wings3D first to get familiar with some of the basics.
7299.35 In reply to 7299.34
Mike, what do you mean when say - world orientation?
www.samardac.com
7299.36 In reply to 7299.35
Sorry, I'm sure that I'm using the wrong words.
I mean which way the x,y and z axes are pointing.
For example, the default seems to be y-up, z label at the bottom of vertical, x to the right of horizontal.
While your spoon example, in top view, has y up, x at the bottom of vertical, z at the left of horizontal.
Show messages:  1-16  17-36  37-56  57-76
