Creating Spirals
All  1-2  3-5
7294.3 In reply to 7294.1
Hi scott - there is a spiral drawing tool that can probably help you, it's a part of the helix command.
Go to Draw curve > More > Helix, and after you place the first point there is a button labeled "Flat spiral" in the command options area that you can press to make a flattened spiral rather than making a helix that twists around an axis.
You can also use the Twist command, that is meant to always twist along an axis so you'd need to create a line that is sloped upwards vertically and then you can twist it into a helix, then flatten that down. But probably the helix command will be easiest.
7294.4
Hi Scott,
Here's a quick example using MoI's own (flat) spiral and the deform (with stretch) tools.
You'll need to play with the curve to get the kind of flared shape each swirl line has in your gif, compared to my example where the outline of each swirl tapers towards the extremity of each spiral base curve.
Cheers,
Hamish
7294.5
Very very helpful. Thank you all.
Show messages: All  1-2  3-5
