Understanding NURBS
All  1-2  3-7
7293.3 In reply to 7293.2
Many thanks - your explanation and the links helps my understanding a little more at least. I can't help thinking though, that being able to play with a mathematical model of a NURBS curve, where all the parameters can be interacted with, would really help.
Are you aware of anything equivalent to this Cubic Splines example on desmos.com, for a NURBS curve?
...some time later...BINGO - these interactive NURBS example should help a lot:
http://geometrie.foretnik.net/files/NURBS-en.swf
http://ibiblio.org/e-notes/Splines/NURBS.htm
http://ibiblio.org/e-notes/Splines/None.htm
I found this page also helpful: http://www.miaumiau.cat/2010/04/nurbs-in-flash-part-1/
(These were the previous closest I came to finding anything useful, [left in because they look interesting] but they're all 'only' NURBS libraries, not interactive examples:
http://verbnurbs.com/
http://threejs.org/
http://libnurbs.sourceforge.net/)
Where this is all leading ultimately, is that I think I want to be able to take a NURBS curve I've drawn in MoI that matches my requirements graphically, then convert/export/derive the mathematical expression of it and embedded that a MoI javascript. Why, because I'm struggling to achieve what I want using a polynomial expression, and I still need the javascript to further deform the geometry, regardless of whether the geometry is expressed as a polynomial or NURBS function.
Any ideas/suggestions appreciated.
Thanks again,
Hamish
EDITED: 9 Mar 2015 by HAIRYKIWI
7293.4 In reply to 7293.3
Hi Hamish, well trying to do a full NURBS evaluator in self contained script code is fairly complicated, if you can deal with a limited number of control points it would probably be a lot easier to just focus on doing Bezier evaluation, that's a lot simpler.
In the future I do want to make evaluation of curves at specific parameter values available to script but currently it is not part of the script interface.
7293.5 In reply to 7293.4
Thanks Michael.
Another idea - what about simply exporting my 'nice' NURB to points (existing script IIRC) and then embedding those points in my script and drawing a 'through points' curve using the existing function? Or am I going to add lumps / loose some smoothness?
-Hamish
7293.6 In reply to 7293.5
Hi Hamish, that sounds like it could be a possibility, but yes it can be possible to introduce lumpy shapes using "through points" although if you have regular spacing that could help avoid that.
7293.7 In reply to 7293.6
Thanks Michael.
- Hamish
Show messages: All  1-2  3-7
