Moi v3 and the Mac issue
All  1-5  6-11
7281.6 In reply to 7281.5
Strangeness continues. I uninstalled/reinstalled v3 and there was no dialog to install the app-it simply unzipped and was ready to use. additionally, the program remembered all of my UI changes from previous installs, but I cannot locate any sort of .ini file.
thoughts?
C.
7281.7 In reply to 7281.6
The moi.ini file is in your Home folder/Library/Application Support which is normally hidden.
To go to that folder click on the Go menu on Finder and while the menu is visible press the Option/alt key. You will Library appear in the Go menu.
Select that and then Application Support / Moi.
Dinos
7281.8 In reply to 7281.7
See attached ini file for review.
C.
EDITED: 20 Feb 2022 by TWOFOOT
7281.9 In reply to 7281.8
Hi Chris, there does not seem to be anything unusual with your moi.ini file, and there are not any settings in there that should have anything to do with this particular problem anyway...
What happens if you make a test folder on your desktop with only a few alphabetic characters in it with no spaces at all, does that make any difference?
7281.10 In reply to 7281.9
For WHATEVER reason, changing all of my folder names to a single word solved the problem. I have never seen such a thing before. Even after a clean install (finally), the problem still persisted.
Thanks to Michael and all for your help.
Chris
7281.11
"Chris Misc."
Could it be the period was the problem?
(reserved for extensions)
Show messages: All  1-5  6-11
