MoI suitable for vehicle designs? Closed
 1-5  6-25  26-45  46-65  66-85  …  126-139
7275.26
Hi Nick,
I agree with Andrei for the most part. If you're into character modeling, then a Sub-D modeler is a good start-- or use a voxel or topology modeler like 3D Coat or ZBrush.
One of the best things about Sub-D is that you can continually 'tweak' the shape of the form, which as you know is all important in concept modeling. If you're planning on building something using NURBs in MoI (or Rhino or Alias like Simon), then you better be correct on the first try, or else you'll need to construct it over from scratch.
That is why you'll see a lot of NURBs models created from real life blueprints and not as much from the imagination, like Vitaly does.
Still, for me, the key is to be as facile as possible in whatever tool you use when creating concept models. If you look closely at Bulgarov, you will see he has created a 'form language' for his models, and he uses it to allow him to 'get it right' on the first (or sometimes second) try. This is really important, and something not easily accomplished-- especially in a 3D modeler. He actually 'sketches' in SoftImage-- I'd assume faster than he can sketch in real life. I also would believe he 'sketches' in MoI as well. I'd bet most of the following were created FIRST in MoI, then imported in SI for final assembly:
He told me the following were done in MoI (and that's the primary reason I jumped into this program to learn).
and I assume:
In fact, I really tried to recreate some of his forms in Lightwave Modeler, as it's very very close to SI in functionality and how it works. See #2 below:
Lightwave:
It was quite a challenge. They were NOT Sub-D but JUST poly only. I still don't know if he used MoI or not for that part of his rail gun. I can certainly see how easy it would be to create in MoI.
I think the point I'm trying to make, is that IF one can actually 'sketch' in their mind, and the application *together*, and 'get it right' the first or second time, then MoI can certainly be great for concept design, just as SI, SketchUp, Lightwave, Nvil, ZBrush and others. For the most part I've been doing a lot of that in MoI on other ID projects (I can't show here). I've found it not that limiting, but then I have had to use SubD for other types of modeling as well. (for instance these are all Sub-D: http://www.argodesign.com/wearables.html )
  More Options
Yes Sketchup in expert hands can makes miracles!
See this guy! http://600v.deviantart.com/gallery/?offset=48
32 pages of Sketchup design crazzy things!
Modeling Sketchup _ rendering Vrayfor Sketchup
By ixlrlxi
  More Options
7275.28 In reply to 7275.27
Passion can make great stuff!! There is no doubt! But how long Passion can compensate this Polygonal Hardcore?
I'm sure if this man want to evolve he will come to Sub-D.
My Portfolio: www.samardac.com
A lot of my Tutorials!
  More Options
7275.29 In reply to 7275.28
I am sure he has tried another softs (he has even tried Moi3d, Lumion etc... ;)
but as it's a designer and it's seems he loves SKetchup from a long time so...
  More Options
7275.30 In reply to 7275.29
Pilou, I also used MoI for a long time to made those MoI LOFT Hardcore. I also tried a lot of other Apps but everytime I back to MoI, thinking that MoI is the best for me, but there was limit of my passion and LOFT Hardcore stopped to work for me. So I become more experienced and found strength to change my workflow to more efficient without loosing Inspiration.
But it is just my experience...
  More Options
7275.31
Hi blindfoldjump,
With what you want to accomplish I would take a serious look at formZ. It has great NURBS tools along with new Sub-Division tools and the ability to change a Sub-Division object to a NURBS object in a single click.
Website:
http://www.formz.com/
Here are some videos for creating complex forms (using NURBS) in a previous version of formZ (before Sub-Division) and all the Sub-Division tools. Note some of the videos are for bonzai3d, which is an older subset of formZ, now called formZ jr.:
https://www.youtube.com/watch?v=2LTD-k2VB-E
https://www.youtube.com/watch?v=TvnaKvoEPek
https://www.youtube.com/watch?v=pOHP6VMMfDE
https://www.youtube.com/watch?v=2NzhMzZg00w
This video shows how to create Sub-Division objects and then convert them to NURBS for additional development:
https://www.youtube.com/watch?v=AGNucQ83__w
Here are the Sub-Division Tools, starts at the 8:30 time point:
https://www.youtube.com/watch?v=zbbLNUyUEeA
Create 2D documents from your 3D models:
https://www.youtube.com/watch?v=m8rfZQOxquM
I love MOI, it is a great modeler, but formZ is really cool, very easy to learn and extremely deep and powerful. It will even do animations of your models. There is a 30 day free trial of the Pro version, so you can check it out yourself.
  More Options
7275.32 In reply to 7275.31
RobertH,
Nurbs to Poly has big disadvantage you can not modify converted objects. If it is not critical when you just Model something but it is critical when you make Concept.
Practically all stuff that you can make after converting Poly to Nurbs you can make in Poly. So my experience show me that it is better to not convert poly to Nurbs. If yo make some parts in Nurbs you can merge them with .obj.
In Internet there are a lot of video showing how converting Poly to Nurbs is great but on practice I find it useful not so often.
  More Options
7275.33 In reply to 7275.30
It's hard to imagine something new :)
  More Options
7275.34 In reply to 7275.32
Hi Andrei,
In formZ you can subdivide objects and have a bunch of Sub-Division tools to manipulate these objects, grow faces or edges, stretch, bridge, squeeze, divide, etc. In addition you can also use the regular editing tools like move, scale, copy, etc on these sub divided objects. When you're finished with this object, you can leave it as is. Or convert it to NURBS or quad-mesh objects. You can of course also make a copy of the sub divided object and hide it, or stick it on another layer and hide that layer, if you want to edit it later.
If converted to NURBS, you can boolean it with other objects (Union, Difference, etc.). You can extract or remove faces and then attach, merge, blend, extend, etc. with other NURBS surface objects.
So in a sense you're right in that you will not be able to edit the object like you could when it was a sub divided object. But in another very important sense it opens up, within a single program, many more options for creating very complex objects and surfaces. You can also make components of these converted objects to be reused in other projects. And it's all very fast and flexible.
So within formZ you can work with regular object (made from extracting lines, surfaces and primitives, etc.), Sub-Division surface objects and tools that work on a per-object bases and NURBS objects and tools like MOI but extended. And they can all be combined.
The NURBS tools in formZ are very powerful and can do a lot of things. Check out the first four videos in my post above.
Of course it's not cheap, costing 3X the price of MOI, but a lot more reasonable than many other apps.
  More Options
7275.35 In reply to 7275.34
RobertH,
I think formZ have no all necessary tools for real polygonal modelling. For example it has circularize tool, that will create circle from polygons to make holls?
  More Options
7275.36 In reply to 7275.32
Mixing Sub-D and Nurbs is probably the way to go, I can't wait Max Smirnov work to see how it turns on real projects.
I do not care about the lack of editing, in practice, editing a sub-d cage model from an advanced model like a car body is a nightmare too.
  More Options
7275.37 In reply to 7275.35
Andrei,
Sure, with a circle tool (three types: one point radius from center, two points diameter, three points: 1 center 2 on edge) set tool option to 3D extrude (six types: 2D surface, 2D wall, 3D extrude, 3D converge, 3D wall, insert opening) and create a cylinder. Move cylinder through object (if you didn't create it in the right place to begin with) and boolean difference, pick object first then cylinder. This works for all objects regardless of surface type.
With planer surfaces (flat) just set one of the circle tools to the insert opening tool option (2 settings: through solid mass, through entire object).
Besides circles there are squares, rectangles, ellipses, and polygons with 3 to however many sides you want (can be changed dynamically) and drawn free form shapes.
  More Options
7275.38 In reply to 7275.37
RobertH,
I meant this:
  More Options
7275.39
Here's a link to Rhino training for making a model of a BMW 5-series:
http://www.mpavlos.biz/index.php?ab=5
He also sells models on his site. Here's a link to his car models to give you an idea:
http://www.mpavlos.biz/index.php?am=3&pr=2
  More Options
7275.40 In reply to 7275.32
Andrei,
I'm not sure what you mean here ...
I though the advantage of T-Splines and PowerSurfacing (PowerNurbs) is that you had a nurbs model that could be edited easily using the polys.
I used PowerSurfacing plugin in SolidWorks. If I wanted to change the shape of the nurbs model that is generated, I just edited the polys as I would in most poly modelers. At least that's how it functions in SolidWorks.
  More Options
7275.41
@Frenchy,
He uses the artisan plugin for sketchup which allows you to do sub'd modelling in sketchup.
You can't create work like this without all the plugins and particularly sub'd plugin.
So it backs up what Andrei is trying to say about modelling vehicle concepts with sub'd.
His work is inspiring though.
It would be interesting to know all the plugins that he uses.
The problem I have with plugins is that as new versions of sketchup are released plugins might not be supported or work (same with blender).
~Kevin~
  More Options
7275.42 In reply to 7275.41
<< It would be interesting to know all the plugins that he uses.
Easy : Just see the interface! ;)
At this date Artisan will not be existing! There were another one Smooth Tools ;)
Even not sure he used it at this date because there were present on the Interface too if yes!
No reason to hide it!
And you have now this free one by Thomthom! ;)
But the new paradigm in polygon modeling is now ZBrush! (The new "ZModeler" function)
EDITED: 27 Feb 2015 by PILOU
  More Options
7275.43
Hello,
Here are some videos that may be interesting to the original request in terms of workflow.
3d-Coat and T-Splines for Reverse Engineering:
http://youtu.be/BUZE0ATWbEM
Modeling a Car with T-Splines for Rhino:
http://youtu.be/ARwhgH3uuVg
VSR Shape Modeling For Rhino Tutorial Of Audi Q5:
http://youtu.be/gT28DocJEE8
The old VSR channel on YT:
https://www.youtube.com/user/VirtualShapeResearch
The 3D-Coat tut may have some application for MoI and the scripts from Max as well, interesting stuff. The TSplines and ADSM (VSR) tuts are a little dated and you may be able to accomplish the model faster using some of the newer tools in those packages but the foundation is there.
  More Options
7275.44
Hey guys!
(Long post here - haven't had time to answer til now, been on vacation)
So many answers! It has taken me quite some time to go through them - checking out the software's you recommended and trying a few of them out.
Andrei:
Thank you for your insights and also your recommendation of using Sub-D's and NVil in particular. It seems like a good software. I already do use Sub-d - I have a license of MODO 801 and I have Sub-d-modeling as a part of my design process. I really like to do the initial modeling in MODO. I have spent about 4 months now in MoDo and I feel that its great for the early design phase - Push/pull polygons to create a base-mesh and to play around try out different concepts. But as this part is completed I prefer going to a Nurbs modeler to finalize things. Getting all the curves perfect and all edges/fillets exactly where I want them - because this has been very frustrating and hard for me to do in sub-d. I understand that this is because I dont have enough skills and understanding of how topology/edgeflow etc works and Im sure I would be able to do it in Sub-D one day if I just practice more, but I think its important to use a tool that _feels_ good - if you know what I mean?
I do respect your opinion, I know you are a very experienced modeler so I will take some time and try out NVil properly (eventhough I already have MODO). Im currently looking through your NVil tutorials on your youtube channel. It does look interesting.
Raoul:
Thanks again for explaining as well as showing your workflow.
I think 40 hrs sounds reasonable, especially as you were learning the tools at the same time.
Im currently trying out your workflow - building rough model in MoI first like you said, and meanwhile I just started out playing with Rhino and going through some tutorials.
Do you by any chance know any good tutorials that could accelerate my learning - except for the ones I can find on Youtube and on Rhino website? (I certainly dont mind paying a bit if they are worth it).
Mauro (M-DYNAMICS):
Thank you for your input and sharing your projects. I agree with you fully that sub-d is the way to go early on, to find the right proportions. I use MODO as well. Would be great to follow along on your upcoming carmodeling project, the ones you showed here looks outstanding – alot of attention to detail there, very cool.
OSTexo:
”Did you also happen to see the model file you could download that went along with the PDF? ”
Ah yes, there was a folder with several Rhino files. I have not tried to do the tutorial yet though. I will try to get the hang on Rhino itself first. I only played around with Rhino a little bit before, but this was in school about 6 years ago now, so I have some catching up to do :)
Yeah you are quite right, it would be beneficial to me to understand continuity since I hope to do designs for car companies in the future.
Interesting stuff there, thanks alot! Cool workflow with T-splines and 3DCoat there. 3dCoat has a lot of very creative solutions, I think we will be seeing more of that software in the future. I tried its sculpting tools abit before and it was not bad at all. I would say that Zbrush appealed to me more for some reason, I think that was due to the interface though.
But anyway, thanks alot for the links. I do wish there was more tutorials on ADSM around though.
Chippwalters:
Oh yes absolutly, being facile and very fluent in the software is my key concern as well. Thats why Im spending alot of time looking around trying out different approaches to hopefully one day find one the suits me. The dream would be to find a software that doesnt hinder or slow creativity, one that actually inspires and speeds it up.
Thank you for sharing that. I was not aware that Bulgarov uses MoI in his workflow. He is a very interesting and dedicated guy, check this interview with him I found on soundcloud, its very inspiring: https://soundcloud.com/the-collective-podcast/the-collective-ep-7-vitaly
RobertH:
Thank you for the recommendation of FormZ. I remember someone telling me about that software a few years ago, but this was the first time I actually tried it out. I was under the impression that it was a tool for architects. I have to say Im pleasently suprised by it. I watched through all the video links you posted and there seems to be an array of tools for complex form creation. I noticed alot of interesting easy-to-use tools in the deform area for example as well.
One question though which I really cant answer myself:
How would the capabilities of FormZ stand up against Rhino(+Shape Modeling) - in terms of surface-matching and controlled form-transitions?
Bisenberger:
Thanks for the link. Looks interesting, I think its a little unfortunate that its a pdf document. Would certainly be worth the 50 dollars if it was a video tutorial, now Im not so sure. I've never been a fan of reading pdf's for some reason.
PaQ:
”I can't wait Max Smirnov work to see how it turns on real projects. I do not care about the lack of editing... ”
Im not sure I follow here, are you referring to the obj-importer?
Kevjon:
Very impressive that he managed to do that in Sketchup. Somehow all the models seem very ”boxy/chunky” I have to say.
EDITED: 3 Mar 2015 by BLINDFOLDJUMP
  More Options
7275.45 In reply to 7275.44
"I have a license of MODO 801 and I have Sub-d-modeling as a part of my design process. I really like to do the initial modeling in MODO. I have spent about 4 months now in MoDo and I feel that its great for the early design phase - Push/pull polygons to create a base-mesh and to play around try out different concepts. But as this part is completed I prefer going to a Nurbs modeler to finalize things."
https://www.thefoundry.co.uk/products/modo/plugins/power-subd-nurbs/
Blindfoldjump - Maybe you have looked at this already ... ?
I've used the SolidWorks version of this plugin. It works fairly well, however, it is not intended for very high number of polys.
  More Options
Show messages:  1-5  6-25  26-45  46-65  66-85  86-105  …  126-139
