IntersectCurve with first and second selection sets
All  1-4  5-8
7268.5 In reply to 7268.3
Wow Michael thank you, it works exactly as I asked.
Using a simple big plane as 1st set, and all the objects as 2nd set, the result of Intersect Curve is an easy way to get zero-depth sections.
M.
7268.6 In reply to 7268.4
> Some example image of all that ? :)
It generates curves of intersection between objects, here's an example with a plane intersecting a second set of 4 spheres - only the plane is intersected with the spheres and not the spheres with other spheres, that's the difference from the regular Construct > Curve > Isect command:
7268.7
This script is useful to quickly make zero-depth sections of the model, by intersecting with a simple plane.
I hope that in the future we will be able to get projected lines as well (of the elements that are not sectioned).
M.
7268.8
This looks really useful! Thanks to Max and Michael!
Ron
Show messages: All  1-4  5-8
