NACA Airfoil script
 1-7  8-27  28-33
7265.8 In reply to 7265.6
Hi Hamish, some great progress!
> I also played with joining a line segment to a curve, before each is committed - it's not
> working yet - I just don't have a grasp on the construct of a GeometryFactory vs a
> GeometryDatabase.
> I got stuck trying to get (convert?) the ObjectList objects from an interpcurve factory into
> a GeomObject object for the join factory. I'm not sure it's even possible, or a correct approach.
One thing you might be running into is if a factory does asynchronous object generation (meaning it actually does its calculation in a separate moi_commandprocessor.exe process, generally used for possibly long running calculations) the inputs you give to it need to be active in the geometry database and not a "loose object" that has just been dynamically created but not added to the geometry database yet. You get a "loose object" if you use factory.calculate() to generate it. These objects currently have to be added in to the geometry database in order for them to be used as inputs to an async factory and Join is one of these types of factories. I'd like to change how this works in the future so as not to have this requirement but it will take some work since some parts of object serialization and deserialization are based off of a unique object id number that is set when objects get added to the geometry database.
> I just don't have a grasp on the construct of a GeometryFactory vs a GeometryDatabase.
A GeometryFactory is something that you use to generate objects, it has inputs that can be set on it, and then for regular commands a call to factory.update() will cause the factory to generate objects and put them in the GeometryDatabase. The GeometryDatabase is not something you create yourself, it's basically the master list of all objects in the model, for example when the screen draws it's every object in the GeometryDatabase that gets drawn.
> [GeometryFactory].getInputObjects() and [GeometryFactory].getCreatedObjects() - are these of any
> use or am I barking up the wrong tree? Where might they be used anyway?
You can call these if you use factory.update() - the call to factory.update() will generate objects and put them into the GeometryDatabase automatically, if you then want to get a hold of an object list of what was actually generated then the .getCreatedObjects() will do that.
Most things in the current scripting environment are heavily oriented towards creating things in the same way as a regular command would, basically by setting some options and then having the objects show up on screen, so usually a regular MoI command just calls factory.update() and does not deal with the generated objects directly itself after that.
7265.9 In reply to 7265.8
I'll be looking at the script over the next few days...
7265.10
Hi Guys,
Pilou - merci beaucoup! :)
Brian - Thanks for taking a look.
Michael, Thanks for your explanations - that's helped a lot, conceptually.
As for putting it into practise, I'm still missing something.
I tried:
var objectstojoin = moi.geometryDatabase.createObjectList();
objectstojoin.addObject( FactoryAirfoil.update().getCreatedObjects() );
objectstojoin.addObject( FactoryLine.update().getCreatedObjects() );
var FactoryJoin = moi.command.createFactory( 'join' );
FactoryJoin.setInput( 0, objectstojoin );
This was the result:
In future, can I somehow capture the MoI javascript error code as text instead of a screen capture?
Cheers,
Hamish
Edit: code now in code block
EDITED: 11 Mar 2018 by HAIRYKIWI
7265.11 In reply to 7265.10
I don't know if it works for your script, but do you know this very simple script console?
https://sites.google.com/site/nakanosoramemo/software/moi3d/script-console
7265.12 In reply to 7265.11
Hi ttype,
Thanks! That's definitely faster for testing parts of a script.
- Hamish
7265.13 In reply to 7265.12
Hi Hamish,
You are trying to use ObjectList instead of Object.
var objects = FactoryAirfoil.update().getCreatedObjects();
for (var i=0; i<objects.length; i++) objectstojoin.addObject(objects.item(i));
7265.14 In reply to 7265.13
Thanks Max!
Conceptually that's really helpful, but now the .update() method returns nothing usable. so I tried:
var objectlist = FactoryAirfoil.calculate().getCurves(); // should return an objectlist of curve items within the objectlist returned by the .calculate???
for (var i=0; i<objectlist.length; i++) objectstojoin.addObject(objectlist.item(i));
Now no error is thrown - but also there is no output - but I'm in a rush.
Will have time to look into it later today.
Cheers,
Hamish
EDITED: 23 Feb 2015 by HAIRYKIWI
7265.15 In reply to 7265.14
Hi Hamish, to put in a code block here in the forum use <code></code> make sure you're not using something like [code] instead.
The problem here is factory.update() does not return anything directly itself, it just causes the geometry factory to calculate the objects and update the factory's own internal lists of objects for what was created. If you then want to get at those created objects you need to call factory.getCreatedObjects().
That's different than factory.calculate() - calling factory.calculate() does directly return an object list to the caller and generates "loose objects" which are not yet part of the geometry database main object list of objects to draw and save in the file and so forth.
So your code would need to be changed to have the .update call on a previous line before you call factory.getCreatedObjects(), something like this instead (and also be modified to deal with the ObjectList that is returned from getCreatedObjects(), you are treating it as a single object being returned rather than an object list), something like:
FactoryAirfoil.update();
var objectlist = Factory.getCreatedObjects();
for ( var i = 0; i < objectlist.length; i++ ) objectstojoin.addObject( objectlist.item(i) );
7265.16 In reply to 7265.14
Hi Hamish,
There is some Joining done in the chain script, and more recently in the _elastica2 script.
7265.17 In reply to 7265.15
Thanks for your suggestions and further explanations.
In a hurry, I was using <code><\code> - i.e. wrong slash direction. :/
I found the .update() .getCreatedObjects() approach you suggested 'sort of works', but leaves 'orphaned display objects'; see my note at the end of the first code block below.
Here's are three 'Join Two Line Segment' examples (can be copy pasted into the script console that ttype mentioned earlier):
Partially working code:
var line_a = moi.command.createFactory( 'line' );
line_a.setInput( 0, moi.vectorMath.createPoint( 0, 0, 0 ));
line_a.setInput( 1, moi.vectorMath.createPoint( 1, 1, 0 ));
line_a.update();
var objectlist_a = line_a.getCreatedObjects();
var line_b = moi.command.createFactory( 'line' );
line_b.setInput( 0, moi.vectorMath.createPoint( 0, 0, 0 ));
line_b.setInput( 1, moi.vectorMath.createPoint( 1, -1, 0));
line_b.update();
var objectlist_b = line_a.getCreatedObjects();
for ( var i = 0; i < objectlist_a.length; i++ ) objectstojoin.addObject( objectlist_a.item(i));
for ( var i = 0; i < objectlist_b.length; i++ ) objectstojoin.addObject( objectlist_b.item(i));
moi.geometryDatabase.addobjects(objectstojoin);
var factoryjoin_ab = moi.command.createFactory( 'join' );
factoryjoin_ab.setInput( 0, objectstojoin );
factoryjoin_ab.commit();
//  line_a.update() and line_b.update() displays those objects, but of course doesn't commit them,
//  leaving 'orphaned display objects' visible: i.e. objects that are displayed, but never selectable after the script completes.
In the end I discovered that using the factory.calculate().item() approach - without using .getCreatedObjects() - does actually work as required.
Here are two examples:
Working code:
var line_a_objectlist = line_a.calculate();
line_b.setInput( 1, moi.vectorMath.createPoint( 1, -1, 0 ));
var line_b_objectlist = line_b.calculate();
for ( var i = 0; i < line_b_objectlist.length; i++ ) objectstojoin.addObject(line_a_objectlist.item(i));
for ( var i = 0; i < line_b_objectlist.length; i++ ) objectstojoin.addObject(line_b_objectlist.item(i));
// Notes:
// .item(i) returns the i'th GeomObject object
// .calculate() returns an ObjectList of objects
// .addobject ONLY takes a GeomObject object
// .addobjects ONLY takes an objectlist
Working code:
objectstojoin.addObject(line_a.calculate().item(0));
objectstojoin.addObject(line_b.calculate().item(0));
// Notes:
I'll update the NACA Airfoil script when I get a spare moment.
Good night, and thank you all your help :)
- Hamish
7265.18 In reply to 7265.16
Thanks Brian. The more scripts to review the better!
7265.19 In reply to 7265.17
Hi Hamish,
You could try putting in a call to factory.cancel(); to have the factory remove the created objects.
But it sounds like you already have a solution!
7265.20 In reply to 7265.19
Yeah, I did try factory.cancel() , factory.reset() and even factory.removeLastInput() but none of those methods removed the intermediate objects.
Cheers,
Hamish
7265.21
Here's the latest NACAAirfoilGenerator script with various minor and a few major improvements since first release:
RELEASE NOTES:
- Now generates all 'basic' NACA four-digit and five-digit series airfoils, including 43012A.
- Variable thickness trailing edge (T.E) implemented.
- Zero T.E. thickness airfoils now draw correctly.
- Conformity of output with official NACA ordinates has been verified* for NACA 0012, 6518, 23012, 43012 & 43012A, see file:
NACAAirfoilGenerator ordinates vs airfoils-2015-03-23.3dm in the attached zip.
* "verified" is probably not the best word, as errors are known to exist in the original NACA ordinate data. As you can see though, output from the script appears to be a reasonable match to the ordinates for the above mentioned airfoils at least:
KNOWN LIMITATIONS:
- Five-digit airfoils with reflex camber lines are not yet implemented.
CAUTION:
A4 coefficient (slider) value input can be set by user 'out of NACA limits'.
- Input parameter validation is rudimentary where it has been implemented.
- TODO: Implement four-digit modified, five-digit modified, and six-digit series - http://m-selig.ae.illinois.edu/ads/naca980820.bas contains working (public domain) code likely worth incorporating.
Generating airfoils with less than 60 chord-wise stations is not recommended as the airfoil's curvature smoothness, when checked with a curvature analysis tool, reduces noticeable. Conversely, generating more than 100 stations doesn't appear to yield much if any noticeable improvement.
I'll make a post about how the thickness distribution curve for the 43012A was generated with an additional reverse-action script another day. That kept me pretty busy for quiet a while.
As ever, any feedback - especially bug reports - is always appreciated.
- Hamish
7265.22
Hi Hamish
Thank you for the NACA skript that you have made. It is exactly what I need for a real aircraft projekt that I plane to build in my
comming reteirement. (NACA 23012)
Since a longer time I know that moi has a big potential as cad program for aircraft development. Not only for curvatures also for
prepairing structures for framework analysis. Together with a friend - because I have no clue in programming - we tryed to handle with lines and points to get koordinates and a sorting of lines to the right points. Short to say: at the end we have been not succesfull.
The goal was to get a .txt file from moi to make an input file for the FEA programm Z88 from the university of Bayreuth/Germany.
If you or someone other of the experienced programmer would like to have an overlook on this thema I would like to prepair all the files
you need to see what is the way of programming.
As you can read english is not my native language so it needs a longer time for me to prepairing my messages.
For the first is here the adress you can have an impression of the FEA analysis programm.
www.z88.de
There are two FEA programms for free. Both are with with all handbooks and tutorials also in english and realy worth to have a closer look.
Specialy Z88 Aurora.
With a positive answer of interest I start to prepaire the example files.
In every case I thank you again for the airfoil skript.
Hans
7265.23 In reply to 7265.22
Hi Hans,
It's a pleasure - and great to know the script might also be used by someone else. :)
I'd be very interested in taking a look at what you're trying to do to combine output from MoI with the open source z88 FEA software. z88 looks really interesting! I know only a little about FEA, but always wanted to learn more. I am just starting to build an aircraft from plans - a Corby CJ-1 'Starlet'. It uses the 43012A airfoil, hence my determination to do a nice job scripting it.
I'd describe myself only as a novice programmer, with interest + determination + internet connection for self-improvement. As such, if your requirements are beyond my current abilities, I'm sure there's enough scripting experience among the forum members to achieve what you need. I think what you're trying to achieve is potentially very interesting to lots more people, so hopefully there will be no shortage of interest in helping.
I would suggest though, that you start another discussion specific to the new script you want to see created - just to keep things relevant and possibly easier for other people to find.
Here's a photo of the award-winning Starlet my friend built (and my lovely wife):
- Hamish
No possible passenger in this cuty plane ?
7265.25 In reply to 7265.24
'fraid not Pilou - just one person and all the glorious blue sky they can eat ...maybe with cake and coffee at a neighbouring field for desert. ;)
- Hamish
7265.26
As people may well start using the NACAAirfoilGenerator script (NACAAG) to make airfoils for real wings intended to take litigious cargo safely into the air - and return it just as safely to terra firma, but mostly out of personal pride, I thought I ought to continue making an effort to check the accuracy and quality of its output. That said, I make no claim as to the suitability of the script for any purpose so please DOUBLE-CROSS-CHECK everything it generates meets requirements before relying on it. The full legal disclaimer is included the JavaScript file. Right, enough quasi-legalese waffle... Here's what I've done and discovered so far:
I generated a NACA 23012 airfoil of '100 stations' and 100mm chord length with NACAAG, and compared it firstly with the ordinates and secondly the curve made from the ordinates generated by naca456.exe* - using the input file '23012_dencode3.nml' (below) to generate the greatest number of output points possible; '98 stations'.
Comparison 1
At a number of randomly chosen stations, I measured the perpendicular distance from points generated by naca456.exe to the NACAAG generated NACA 23012 airfoil curve.
Differences of between 0.00001mm to 0.000049mm were observed. Those differences are well within manufacturing tolerances, but why any difference at all? I suspect it may be due to (cumulative) rounding errors - or possibly truncation error, due to the naca456 airfoil ordinates (to 6 DP) being scaled from unit 1 to 100 in CAD, rather than in script. Any other ideas?
Comparison 2
Using Rhino's Curvature Graph tool, I compared relative smoothness of the NACAAG generated NACA 23012 and the through point curve created using the MoI ImportPointFile script and the file 'NACA 23012 points from naca456_dencode3.xyz' - which is simply the actual naca456 ordinate output file, '23012_dencode3.out' reformated to xyz and rearranged to enable one continuous through point curve be created. Considering the relatively small differences measured in Comparison 1, I find the contrast between the two curvature graphs in the following screen capture quite surprising.
It's reassuring to know that the smoother of the two airfoil curves was generated by the NACAAG script, but I have my doubts a wing made using either method would look much different in real life after coming out of the paint-shop. Any thoughts from anyone who uses curvature graphs as part of a pre-manufacturing inspection process? What for example, is a reasonable rule of thumb for setting curvature graph display scale to avoid unnecessary rework of a curve or surface?
As an indication of just how much cross-checking needs to be carried out to verify the results of a new script, the airfoil ordinate generator basic code I previously mentioned - http://m-selig.ae.illinois.edu/ads/naca980820.bas appears be generating unreliable output. Now it could be that the three DEF functions I needed to removed from that program so as to make it acceptable to the QB64 basic compiler on my Win7-64 machine were in fact being used, but I couldn't see where. I'll try to find out why the results are not as expected directly from the author. For the meantime, and especially because I'm not certain I haven't created the problem myself, I won't publish any comparison results - just be aware.
* naca456.exe is a public domain airfoil generator program written in Fortran by renowned aeronautical engineer Ralph L. Carmichael. As he notes on his site pdas.com, naca456 is a further development of NASA's work, first documented in the 1970's, to create a computer program to obtain ordinates for NACA airfoils.
- Hamish
EDITED: 28 Mar 2015 by HAIRYKIWI
7265.27
Latest (minor) release:
Point access syntax bug discovered under MoI V4 beta - now compatible with MoI V3 and V4.
Bug squashed by r2d3 - many thanks again Ralf :)
Show messages:  1-7  8-27  28-33
