TrimCommand
726.1
Halo Michael,
Little problem in Trimfunktion ? See picture
BestReg`s EDDI
EDITED: 4 Jul 2007 by EDDI
726.2 In reply to 726.1
Hi Eddi, thanks for posting this bug, especially with the 3DM file that really helps a lot!
This was a bug in handling trim points at self-intersection areas on curves, I've fixed it now for the next beta release.
726.3 In reply to 726.2
Moi-TrimCommand is a very good function !
>handling trim points at self-intersection areas on curves.
Problem in a lot of other 2d-3d-programs. (To date without Solution).
Thank you for your effort !
Generally question to TrimCommand: It will be possible, to find all intersections automatic?
BestReg`s EDDI
726.4 In reply to 726.3
Hi Eddi,
I think the next beta will have the solution for you! :)
Yes! The way it works is at the "Select cutting objects" prompt, you can also just push "Done" (or right-click) there if you want to cut each object with one another.
However, in the current beta it will only calculate self-intersection points when there is only one single curve selected as the object to trim. I have changed this for the next beta so that it will always look for self-intersection points on curves, even when there are multiple curves involved.
So in the next beta if you select both those curves, then run "Trim", you can just hit "Done" instead of picking any Trim points and it will find all of them automatically.
726.5 In reply to 726.4
Thank you very much, coole thing
BestReg`s EDDI
