Little help.....
All  1-2  3-4
7256.3
i was exporting all 3 as an stl and printing. i suspected there was a way to make them one object.......i was trying join, but now know to use the boolean union command.
thanks for the speedy response. it is one of the things that make MoI a great program to work with!
7256.4 In reply to 7256.3
No problem joe! Join can be used when you have individual surfaces that have edges touching each other. Join glues individual surfaces like that into a connected piece.
The booleans on the other hand work with solids and will intersect the pieces with each other, slicing some pieces out and then connecting them up into a new combined solid.
So if you have a bunch of surfaces you want to glue together, Join works for that, if you have solids pushing through each other use booleans for that case instead.
Show messages: All  1-2  3-4
