Offset or Scale?
All  1-2  3-5
7253.3 In reply to 7253.1
Hi Nick, another possibility could be to draw a circle off to the side a bit, then select the circle and run Construct > Sweep, then select the path curve and you will then have a tube object that follows along your path curve.
Now with the tube in place, select the tube and the face that you are interested in and run Construct > Curve > Isect - that will calculate an intersection curve between the tube and the face and that looks like the kind of result you want.
See attached 3DM file with the tube and intersection result in place.
7253.4 In reply to 7253.1
Or another possibility using surface offsetting similar to described before could be to select these 3 faces:
Then run Construct > Shell and choose a pretty small thickness value. That will leave those faces in place to become openings, and the surrounding surfaces will get offset and intersected with the original surfaces, making edges like this:
So then select those edges, use Ctrl+C to copy them to the clipboard, undo to revert back to the pre-shell state, and then use Ctrl+V to paste in the curves you want.
7253.5
Thats outstanding guys! Thanks alot for taking the time to help me on this.
Show messages: All  1-2  3-5
