quad mesh export
All  1-6  7-10
7211.7 In reply to 7211.6
Hi PaQ,
> Those automatic system also create very dense mesh, and doesn't really care about creating
> loops along sharp edges to keep tension right.
One of the areas that the existing automatic systems tend to have difficulty with is trying to deal with changes in scale, like when small detailed features are close by larger undetailed flat areas.
They often tend towards trying to make uniform sized quads throughout the whole thing, and then in order to capture some smaller details that uniform target size has to be pretty small.
One of the difficulties with trying to do similar things to CAD models is that CAD models can very often have that type of scale changes for different features like little cut out areas inside of a big flat plane.
Usually when an artist is doing retpology work they are using a lot of skill and judgement to guide the topology that is being created. Processes that require that type of judgement about them tend to be fundamentally difficult to automate, it's like trying to create artificial intelligence...
7211.8
Hi, I'm recently needing this feature for doing texture displacement. For example I have a wall and I apply a brick texture with displacement. So it doesnt have enough geometry from MoI and I have to subdivide the mesh but the subdivision doesnt go well with ngons nor triangles. So, itll be very usefull to have just quads because textures with displacements are very common on arc viz.
7211.9 In reply to 7211.8
Hi Ed, for displacement it's generally good to use the "Divide larger than" setting to generate more evenly diced up triangles.
See here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2833.5
So do you mean you're trying to do the subdivision _after_ you've done the transfer from MoI into your other app?
If so then try doing it at export time from MoI instead, using "Divide larger than" as shown above.
That should produce a better result since the subdivision will be based off of the CAD model instead of trying to generate polygons on top of polygons.
7211.10
EDITED: 30 Oct 2022 by ZARKOW
Show messages: All  1-6  7-10
