cutter asst
All  1-3  4-5
721.4 In reply to 721.3
Hi Pat, this way will be a lot better, you won't fill up your attachment space nearly as quickly.
Just one more thing - when you create an image to attach if you can create it using the JPEG image format (the file ends in .jpg), that is a much more efficient format space-wise than BMP which you've got here.
So for instance each of these images saved as a BMP file here are 2 Megabytes, while the same image saved as a JPEG is around 90 Kilobytes, which is less than 1/20th the size.
So if you use JPEGs, you will be able to attach 20 times as many images before filling up your alloted attachment space...
721.5 In reply to 721.4
I give it a try thanks for the help!
Show messages: All  1-3  4-5
