AI Export Problem Mac 3.0-Bug report?
All  1-8  9-11
7209.9 In reply to 7209.8
Hi Scott - in your example file the curves exist outside the page, it's just the default page view in preview that won't show them.
In any actual editing environment you should be able to access the curves that are not within the current page boundaries.
For example if I open your posted file in Adobe Illustrator, I'm able to zoom out just a bit and select and work with your full curves, they are still there just sticking out a little bit past the page, it looks like this:
This should normally be the case in any 2d vector editing program that you would load it into - doesn't it work the same way in Inkscape too?
Yes, a preview specific app like Adobe Reader or OSX Preview will probably only display whatever is on the visible page portion of the data, that's because they are focused on just showing you what would be printed if you were to print the PDF, they are not really set up to display all the entire data like an editor program will.
But if you want all the exported vectors to fit within a regular page, there is an option you can set at export time from MoI to make that happen, it's the "Scale: Fit to page" setting which is located here:
When you set that option, all the vector output will be scaled and centered such that all the output will fit within the page boundaries and it should then be immediately visible even in preview specific apps.
Right now you are using the setting "Scale: Preserve units", rather than "Scale: Fit to page" - when you choose "Scale: Preserve units" the scaling is done in a more limited way such that specific units in the MoI model will transfer to specific unit sizes in the page coordinates. So you can do things like make 1 inch in MoI end up being 1 inch in the printed page as well. When you use this mode it can be good for controlling exact sizes for physical cutouts or things like that, but it will have a side effect of things easily going off the page like you have seen. If you don't care about preserving physical sizes of things and just want everything to fit within the page (which it sounds like you do), then the setting "Scale: Fit to page" (as shown above) should do exactly that for you.
Hope this helps!
7209.10 In reply to 7209.8
Hi scott - just one more note on this, you wrote:
> I would expect doc size to be adjusted to be a bounding box of the objects and also
> to be translated to 0,0 relative to the document.
As far as I have been able to tell, PDF is kind of intended for the document size to be one of the standard physical printed paper sizes.
So because of that, the MoI PDF output does not try to set some custom page size that would have no relation to standard print sizes, it just makes the page size to be the 8.5 x 11 inch letter page size.
In the future I think I'd like to have some options to control that, maybe just with some different standard page sizes listed but for now it's just fixed at a 8.5 x 11 inch page size.
Then the way you can control it currently is if you want the output to fit entirely within that page, you can use that "Scale: Fit to page" option to make that happen.
If you care more about preserving specific unit sizes of your objects, then you would use the "Scale: Preserve units" option (which must be what you are using currently), which will still have the same page size but the output will be focused then on only doing some minimal processing of the curves so they remain as much as possible at the same coordinate locations and coordinate sizes as they were in MoI - this will often result in them being located somewhere off the page or sticking out past the page or things like that, unless you have controlled their placement within MoI to correspond to what you need. For "Scale: Preserve units" mode it can help if you make a rectangle object that will map from 0,0 to 8.5,11 inches in converted units so you know where you should put your objects so they will land on the output page.
But again if you just want things to fit inside the output page and you don't need to preserve some specific unit sizes, just set "Scale: Fit to page" and you will not need to worry about that type of stuff after that, at least that's what is intended.
7209.11 In reply to 7209.10
Thanks Michael. Indeed I can open them in Inkscape, change the document size and then output them again as PDF before I pass it on. You're right that PDF assumes some sort of a physical paper size but it can be any size up to 38,100,000 cm^2 (if the library supports custom paper size). I would like someday some choice in paper size (or at the very least landscape vs portrait would help in some cases). It would be also nice to translate to document origin + margin without scaling, again this is mostly for communicating to someone. If I'm going to use them for cutting, I don't mind a step through another program.
Scott
Show messages: All  1-8  9-11
