Cycles for MoI
 1-13  14-33  34-53  54-73  74-93  94-113
7208.34
OSX:
I managed to get Cycles standalone running on OSX, also managed to write out an .xml file into the temp folder with your script!
Then with Terminal, I rendered it with Cycles. With this script:
/Applications/MoI\ v3.app/Contents/Resources/drive_c/moi/cycles/cycles /Applications/MoI\ v3.app/Contents/Resources/drive_c/users/Wineskin/Temp/ball_square_scene.xml
But not a programmer, so didn't understand how to edit your script so it does this automatically.
http://blender.dingto.org/cycles_standalone/Cycles_OSX_10.9_x86_64.zip
EDITED: 8 Feb 2015 by FAKEPILOT
7208.35 In reply to 7208.34
When you say that
"Then with Terminal"
How do you process for access to a "terminal" ?
7208.36 In reply to 7208.35
Oh, in Applications > Utilities - you will find the Terminal app.
With the Terminal app opened, you can drag your Cycles standalone app there (to get it's location), then add a space and then drag your xml file to the Terminal window and hit enter.
This will render your xml in Cycles standalone on OSX.
Did this very fast test, to see if it worked. Pretty sweet render of glass in 30 seconds on a laptop! Like the Cycles renderer! :-D
Size: 390.8 KB, Downloaded: 210 times, Dimensions: 1072x774px
7208.37 In reply to 7208.36
What's the way to process ball_square_scene.xml
Can we imagine have some cursors in Moi for input the Different shaders against input them by hands?
And what about textures ?
EDITED: 9 Feb 2015 by PILOU
7208.39
Very nice work Max! Thank you very much! :)
I had a few problems, described below, which might be a bug with the MoI script - and/or help someone else.
A big problem remains however: Cycles still isn't writing the png image to the snapshots folder despite reporting that it is, (see the screen capture below). Any ideas appreciated.
My Win7(64) was reporting compatibility issues:
- The first script didn't work, other than the Cycles window flashing open-closed after I specified the mesh geometry in MoI.
- The second script seemed to work for a while, then, after pressing Q to save and quit from Cycles, Win7 reports Cycles had terminated incorrectly and was searching for a solution; nothing saved either.
- Next time Cycles started, Win7 told me it was applying compatibility settings.
- Thereafter, pressing Q in Cycles displays a message saying it's saving the png in the MoI3.0\snapshots folder, but no file is actually saved there.
- Now I'm right back to the beginning - the Cycles window flashes open and closed after specifying the mesh geometry.
Somewhere along the way (above) I changed the script to "Cycles noexport". At first it seemed to work, then in the Cycles window that flashed open-closed, I could read "xml file not found" or words to that effect. Changing the script back to "Cycles" got it working again.
Cycles reports "Writing Image", but no file is created:
Cheers,
hairykiwi
<< pressing Q to save and quit from Cycles, Win8 reports Cycles had terminated incorrectly and was searching for a solution
Idem for the Q key !
7208.41 In reply to 7208.40
Hi PILOU
Sorry, I don't understand: What is "Idem"?
7208.42
Fake Pilot
Wait for a new version which supports manual folder settings.
Frenchy Pilou
Not now.
hairykiwi
Try to run MoI with administrator rights. Your Program files/MoI/.. folder is write protected.
It will be better if you'll wait for the new version. With this version you can move cycles and snapshots folders everywere you want.
7208.43 In reply to 7208.41
Hi :)
idem is a latin word that means : "the same of "
@Pilou
means: " same thing for " Q key
M
7208.44
Max, thanks.
I tried running Cycles as admin, but not MoI - I'll give it a go. In any case, a snapshots folder outside the Program Files folder is much more preferable - looking forward to that, thank you.
Mauro,
Doh! Sometimes, even when seemingly hard-wired to the net, I overlook using a search engine to make up for my poor language skills. Thanks for educating.
Here's a bit of trivia: rather coincidentally, while I was learning/working on a MoI script earlier today, I thought, 'Where does the word 'factory' actually come from?" Searching for "factory etymology" shows the Latin factorium is literally, ‘oil press’; the English language makes more and more sense all the time, after discovering its roots. :)
7208.45
version 0.98 :)
Added:
[TR] - transparent shader
[CH] - checker texture
Default material changed to [V:100] Velvet
Increased default background brightness
Now script stores location of the cycles.exe in the moi.ini. You need manually choose a location of the cycles.exe.
Also you need to create "output" subdirectory in the cycles directory.
Use "_cycles reset" command to reset script settings.
EDITED: 7 Mar 2022 by SMIRNOV
7208.46 In reply to 7208.45
French Manual Updated :)
http://moiscript.weebly.com/cycles-pour-moi.html
And what about Textures ?
7208.47
Cool stuff!!! thanks for posting.
7208.48
Finally, v.1.0
Optimized emission styles export.
Pilou, this script is good for beginners, and maybe for fast(test) rendering. But I don't see any reason to make a material library in the MoI or textures support.
There are many good render programs which do it much better.
7208.49 In reply to 7208.48
No problem! :)
7208.50 In reply to 7208.49
Pilou, could you change thread name to "Cycles for MoI"? :)
7208.51
Question. Is there a way to set the render mode to GPU?
Max.
7208.52 In reply to 7208.50
<< could you change thread name to "Cycles for MoI"? :)
Me I can't, but Michael yes! ;)
7208.53 In reply to 7208.51
GPU rendering disabled in this build. I can't find the last build. Only sources.
Show messages:  1-13  14-33  34-53  54-73  74-93  94-113
