Modeling exercice...
 1-7  8-27  28-41
7196.8 In reply to 7196.5
Max Smirnov has been working on a subd converter for Moi, go here http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.68
Subd modeling for nurbs is now becoming available in several applications. I believe the new ViaCAD Pro (less expensive than Rhino with T-Splines), as well as FormZ have this ability now.
Also check out Resurf3d, they have a stand alone converter that will take an OBJ with quads and convert it to a smooth IGS surface and its only $80, but you can't edit the shape of the subd in the converter, you would have to go back to your poly modeler. Not as ideal workflow, but less expensive.
EDITED: 24 Jan 2015 by CHRIS_DORDONI
7196.9 In reply to 7196.8
thanks chrisd
i've put the 2 files into command folder of MoI but i dunno how to call this command and how i can use it ?
7196.10 In reply to 7196.9
hi Finema,
Actually, I don't own Moi yet, I've been following it closely here. I'm sure someone here can help you that. You could try posting in that thread relating to the script.
7196.11 In reply to 7196.10
ok i found how to use this command but don't match with complex form...
subdiv_beta have just a good job with simple polygonal form
7196.12 In reply to 7196.5
Hi Finema,
> Are you sure T-Splines plug-in convert very well complex form ? Just remind, in my work, i
> must sending professional IGES to the manufacturer.
I've seen some examples of complex jewelry pieces that were successfully converted to IGES so I think it can work well for that.
It may be a good method to test out anyway if you want to construct things in a sub-d modeling program and then convert to NURBS surfaces (in IGES or STEP format) at the end to transfer to CAD.
7196.13
Hello,
Looking at this a bit I think I would use the existing plans petal edges, determine the depth of the petal at a few places and then make sure I started the petal closer to the front center of the bottle and Sweep the curve past the outside of the front center bottle edge. I'd then use Sweep to get the actual surfaces.This would get me the cutter stamp of the bottle. The last operations would be the easier ones (on second thought, everything looks difficult on this model), I think the XO bottle doesn't actually have a scalloped center, it just looks that way because the (chamfered?) ellipse is Booleaned from the inside of the bottle. The same on the outside, that is why it would be important to actually send the petal surfaces past the edge of the bottle, I don't think the outside profile is actually straight, it looks like you would need to develop a second curve set to Merge and make the solid. You'd be left with some hard edges which would require some filleting work. The bottle looks symmetrical, so you can Mirror the item. It's almost as if you could create the petals as an object to Boolean, then create the bottle and cut that petal stamp away from the bottle. Either way there is nothing simple about the project. Another option is to have a bottle scanned and then use that for the surfacing reference for something like Autodesk Shape Modeling or Tsplines.
7196.14 In reply to 7196.12
Michael,
I have construct the bottle in sub-modeling. Perhaps somebody on the forum, could convert this file into Nurbs ?
7196.15 In reply to 7196.13
Hi OSTexo,
I understand the idea but very hard in practical. I've tested a lot of things but never i've finish because i through it wasn't the right way to process.
7196.16
Hello Finema,
Is it possible to post the file, in whole or part? Also have you or your vendor considered STEP as a format? Sometimes IGES can require post processing for some surfaces.
I just remember that you can use Fusion 360° for free as personal use
http://fusion360.autodesk.com/pricing and press "Do I qualify for free use ?"
You can directly have TSpline to Nurbs...so export to Moi or ...
But I believe that possible in Moi with something like this! :)
EDITED: 25 Jan 2015 by PILOU
7196.18 In reply to 7196.17
1• I've tried Fusion 360 and YES I've convert my .obj into IGES and Open in MoI. (in attachment the Xo decanter in .IGS)
2• Unfortunately,I prefer to realize this form directly in MoI.
EDITED: 28 Jul 2018 by FINEMA
7196.19 In reply to 7196.18
Excellent!
I believe that you can with MOi as I show you above, if you draw the all the edges (with the good form bottom + bottle neck) then Sweep, network, joint, ... them!
You have now the model for do it! :)
EDITED: 26 Jan 2015 by PILOU
7196.20 In reply to 7196.18
Hi Finema, it looks like the Fusion 360 conversion worked well!
What is it that you're looking to gain by modeling this in MoI?
MoI is probably not the right tool for this particular kind of a job - MoI is more focused on constructing objects from 2D profile curves. That works great for a lot of mechanical objects, but organic shapes with lumpy bumpy areas are not a good fit for that type of workflow.
Things with lumps and bumps tend to be better accomplished using the organic modeling toolsets which polygon modeling programs are heavily focused on. They focus more on a sculpting type approach pushing and pulling parts of the model around, it's pretty different from the profile curve method that MoI is based on.
The overall modeling mechanisms used in polygon modeling just tends to work better for jobs like this.
Different kinds of models tend to be suited for different kinds of modeling mechanisms - the type of mechanism that MoI is based on works really well for certain kinds of objects, and not so well for other kinds of objects. It's best to use MoI for the projects that it is suited for, and to use different tools for projects that they are better suited for.
7196.21 In reply to 7196.20
OK, thanks Michael.
7196.22 In reply to 7196.18
Hello Finema,
I've attached a file with some ideas for the hard way. I've tryed to reconstruct the shape, based on the given drawing - but some informations are missing( depth of the place for the lable, ...). After you have reconstruct all faces and get an impression of the underling geometries, you have to redesign all surfaces with a reduced number of controllpoints (look at the curvature comp:( ). I have used some geometrical assumptions, that might not be correct - it's only one way to find the underlying shapes. The used geometry is hidden in the file - have a look - I hope that helps;)
Kind regards
Karsten
p.s.: In the file are some tolerance problems, it's q-n-d - so don't use it for your test!
EDITED: 18 Jan 2019 by KMRQUS
Size: 148 KB, Downloaded: 47 times, Dimensions: 1037x1133px
Size: 62.6 KB, Downloaded: 39 times, Dimensions: 542x1129px
7196.23 In reply to 7196.22
Hi karsten,
I've looked the file but i don't understand the red plans ?
7196.24 In reply to 7196.23
Hi Finema,
I have draw some Tangent lines to geometry in the sideview of the bottle(look at Dimensions 5mm-7mm). Then I draw some curves in the front view. After extrude them I make some intersections, to get curves for some Network, sweep ... (very classical method known from sign boards). Normally You have to have the top-view and sections also, to get better results. So you have to guess the form. But nevertheless it's an interesting object for experiments;-)
Have a nice day
Karsten
7196.25 In reply to 7196.23
p.s.: As some People said before - moi is good for fast create and draft designs, shape your creative minds - for such a Job your program needs deep history mechanism (Feature trees Catia V5, NX,... ), constrains and parametric abillities and/or advanced direct methods (syncronous NX/solid edge, spaceclaim, CATIA VX...) to avoid recreation the geometry again and again, till you find a good result.
So Fusion 360° is maybe more suitable because it has such things! ;)
7196.27 In reply to 7196.26
yes i understand MoI isn't the best product to design this form.
In fact, I've already modelled it in C4D (polygonal result) and i wanted to test MOI with this challenge.
For me, the best result was to draw lines in facing and project it on a taurus but i've stopped because i could not use fillet on it, etc....
I think MoI is really good for creative design without constraints but less to reproduce complexe form WITH PLAN as in my example.
Show messages:  1-7  8-27  28-41
