Voronoi Script or plugin
 1-3  …  24-43  44-63  64-83  84-103  104-123  …  184-198
7177.64 In reply to 7177.63
...you want the "moon" :)
7177.65 In reply to 7177.64
less than one half =)
7177.66 In reply to 7177.63
> will this fix also keep a similar distance between curves?
The usual trick is to have a distance between the edges was that one draws
a control point curve around the corners of each cells and offset then a little
bit inwards.
That's how i have done it in the past with my Voronoi Eggs.
https://www.behance.net/gallery/34247989/Voronoi-Egg-CVT
7177.67 In reply to 7177.63
Hi glmr,
yes.
between polygons
7177.68 In reply to 7177.66
did you make these eggs in Moi3d??? I thought it is possible only with Paneling tools from Rhino
7177.69 In reply to 7177.67
nice! looking forward for your update
7177.70 In reply to 7177.68
i used various tools to create the voronoi structure and finally used MoI to model the eggs, so no paneling
with Rhino etc.
7177.71
7177.72 In reply to 7177.71
My Moi French Site My Gallery
7177.73 In reply to 7177.71
Thanks a lot Max !
7177.74
Thanks Max
www.jameselliott.co.uk
Always funny!
7177.76 In reply to 7177.75
how???
7177.77 In reply to 7177.75
Very very nice!
7177.78 In reply to 7177.76
<< how???
_Voronoi
Extrude "Tapered"
Flow on a Sphere
Render in free Real Time SimLab Composer Lite (max 1920 * 1080)
Have fun!
Here Corners of Voronoi are >90 so rounded (put 0 if you want sharp forms)
EDITED: 4 Mar 2018 by PILOU
7177.79
Voronoi.v.1.0.2018.03.05
Changed random algorithm.
Fixed bugs.
http://moi.maxsm.net/item/48
7177.80 In reply to 7177.79
Thank you very much for your constant developing!!
Voronoi script is a extremely useful tools to create very different kinds of geometric CG!
I'm experimenting some cool stuff with Moi + Voronoi and iPad Pro.
With the new _Voronoi by Max Smirnov:)
Take 2 sets and use the ISect Boolean Function! ( whith Union Sets disabled )
then ExplodeMove hidden function
Have fun!
Here twice the same but you can take any things! :)
PS French Version Updated!
http://moiscript.weebly.com/scripts-de-max-smirnov.html
EDITED: 8 Mar 2018 by PILOU
7177.82 In reply to 7177.78
thanks!
Hello Max and everyone.
I had some fun with your Voronoi and the iPad Pro (Affinity Photo, PixelMator, Procreate 4, Snapseed).
Ciao!
Marco (mkdm)
EDITED: 6 Mar 2018 by MKDM
Show messages:  1-3  4-23  24-43  44-63  64-83  84-103  104-123  124-143  …  184-198
