Voronoi Script or plugin
 1-20  …  141-160  161-180  181-198
7177.181 In reply to 7177.180
Thank Michael, I'm going to have a look at it , I just rarely like to leave MOI3d , everything is very convenient there.
Seems you can make some 3D voronoi with only 2D ones ;)
i don't remember How I made that: a moment of inspiration! :D
Hi Roni,
I did with my friend Jotero lot's of 3D Voronoi Volume Mesh stuff in the past.
I am not aware of any tools for MoI that allows you 3D Voronoi points sampling
to obtain surfaces from them.
However, I attach a small tutorial (in German language) so that you can see
how one can do it with freely availabe Polygon Mesh Tools.
Please Note: the mentioned GTKRemesher, for obtaining excellent triangular
meshes is no longer available, you need to search the web to obtain a similar tools.
Best regards
Another option would be to try to get the tool "GEEX",
which was once available from a French researcher in
this field. GEEX must be compiled and runs only under
Windows.
Does the Jotero forum always existing ?
Just find this free tool online :)
Result is in PLY so use MeshLab for convert it !:
https://www.voronator.com
EDITED: 9 Jan 2020 by PILOU
7177.187 In reply to 7177.186
as I remember also Blender can make 3D Voronoi.
@Pilou, the forum no longer exists.
@Rudl, yes, you can do also Voronoi stuff with Blender, however to obtain excellent results,
like a Centroidal Voronoi Tessellation (CVT), you need tools like GEEX etc. to sample the points set properly.
Blender can't do this and the results looks therefore not good.
P.S. See for example my Voronoi Eggs, I did once in MoI, at my Behance gallery, which use also CVT.
7177.189
Meshmixer is able to do 3d voronoi shapes.
Skip to 8:40 in this video:
https://www.youtube.com/watch?v=kh5jKgsEQak
EDITED: 10 Jan 2020 by WAYNEHILL5202
Inside free Wings3D also ;)
Special "Manifold" version! (there also many cool functions in these extension !
https://www.dropbox.com/sh/3cwsi5kvm0jeiae/AACWabcUIFe8UObZoyOvSQ6Ca?dl=0
EDITED: 10 Jan 2020 by PILOU
Message 7177.191 deleted 11 Feb 2021 by MARK-LI
Hi Max,
I hope that you are well!
Because I do not find the 'ping Max' thread, even after searching, anymore,
I would like to ask you, in case you have time and like to do so, if it would
be possible to allow users also to create a Delaunay triangulation, besides
a Voronoi Diagram, with your superb script?
Best regards
7177.193 In reply to 7177.192
you have this one ?
https://moiscript.weebly.com/objects2.html#delaunay
Here random points but i suppose you can input of course your own points ! ;)
It's me or the Voronoi plugin has not "Line, Polygon Curve" Working ? Only "Line" is enablelable!
EDIT i have an old one! :)
EDITED: 15 May 2021 by PILOU
thanks, but I like to have that like Max's script and do not want
to use NodeEditor for surfaces etc. and only like to use 2D line art.
7177.196 In reply to 7177.192
@Futugoza
Maybe this can help you ?
Here Proof's Points was drawn by hand (copy/Move) not by the Elephant nodal system by Max Smirnov!
Triangulation is drawn by the Elephant! :)
EDITED: 16 May 2021 by PILOU
Great Pilou,
thanks a lot!
For someone who ask how i made that :)
You can use the last plugin of Max Smirnov
http://moi.maxsm.net/files/scripts/Voronoi.v.1.11.2018.03.09.zip
or maybe also the Elephant with some regulates :)
Show messages:  1-20  …  121-140  141-160  161-180  181-198
