Voronoi Script or plugin
 1-6  …  107-126  127-146  147-166  167-186  187-198
I mean something like this, not finished of course.
But IMHO the pattern looks now nicer, because of the evenly
spaced denser points.
Bildschirmfoto_2018-03-10_um_22.43.12
A new font! :)
My Moi French Site My Gallery
He he, yes this could be an interesting field to be more explored...
But i think when i do this i have to much geometry with caps etc., for my little iMac.
So i do now first tests with math related doodles, without caps, to keep the polygon count low in MoI.
I've noticed that pre-selected points do not have to be in the z = 0 plane.
The voronoi script seems to ignore the z values (?) of the points, and treat them as if they were in the z = 0 plane.
7177.151 In reply to 7177.144
Works great!
Thanks Michael!
My first math related Voronoi doodle with Max's script and Michael's tip, a Fermat spiral.
voronoi_spiral
Will be suitable for stained glass! ;)
Does it possible to strain the number of sides of polygons ?
so 4 will done only quadrangles, 5 hexagons etc...
for some connexion with this sort of thing! ;)
http://www.tsg.ne.jp/TT/cg/TachiFreeformOrigami2010.pdf
7177.155 In reply to 7177.154
thanks!
having so much fun With Max's script and Michael's tip. :-)
Mo_I_Voronoi
Voronoi is the dual of Delaunay Triangulation.
You will have to experiment a bit with drawing some triangles to understand how Voronoi works.
EDITED: 11 Mar 2018 by STEFAN
7177.156 In reply to 7177.141
Hello mat10X.
Thanks.
@You "...how are you going from control points to the individual points on the curve/path to create the Voronoi?..."
Simply!
With one of the amazing scripts made by Max Smirnov! : PointsOnCurve
Grab it here : http://moi.maxsm.net/media/files/
This is the script you need :
Ciao!
7177.157 In reply to 7177.143
Hi Finema!
Very cool!!!
This the kind of CG style a really like :)
Bravo!
7177.158 In reply to 7177.145
Hi SBEECH!
Very nice!
I too want to experiment something like that, but using voxels in 3D-Coat.
Maybe tomorrow I will post some test render.
Ciao!
7177.159 In reply to 7177.155
Hello Stefan!
@You "...He he, yes this could be an interesting field to be more explored......"
Oh yeah! Almost endless exploration ;)
Very cool this kind of "Text Voronoi art"!! Very cool!!
A sort of...."specialized branch" of very nice "industrial design" IMHO.
Thanks a lot!
7177.160 In reply to 7177.159
Hi Marco,
yes, lot's of things can be explored, thanks to Max! :-)
As a little test you can try the following, draw some random connected triangles and use Michael's
Circumcenter script. Once you have the points connect them with straight lines and voilá you have
a Voronoi Diagram over you triangles. :-) You can use of course Max's Voronoi script, but this way
you see the process better.
7177.162 In reply to 7177.156
"Simply!
With one of the amazing scripts made by Max Smirnov! : PointsOnCurve"
Of course...Max!
Works like a charm. Michael's suggestion also works very well. Good to know the base manual operation. Getting spoiled with these amazing scripts.
Thanks Marco (Max and Michael)!
7177.163 In reply to 7177.162
Hi all,
last doodle for today. :-)
Voronoi_Spiral_Regular
7177.164 In reply to 7177.163
Hi Stefan, those would make nice stained glass or mosaics!
thank you! I may do small pieces from some of them later, to print out in color
on our 3D printer at work.
Can't wait what Marco and all others will come up with!
An old one! :)
Show messages:  1-6  …  87-106  107-126  127-146  147-166  167-186  187-198
