Voronoi Script or plugin
 1-7  …  88-107  108-127  128-147  148-167  168-187  188-198
7177.128 In reply to 7177.126
Hi Max,
i tried your script (old version) under OS X with 5000 points but i don't get the desired result.
For comparison i attach pictures from Adrian Secord's Weighted Voronoi Stippler (2) and MoI (1) script output.
I used his points output for x,y and added with sed z = 0.0000000 coordinates.
Attached is also the points file.
O.k. scaled now with factor 100, much better, but still not there.
Maybe i have to try MoI v4 with your latest version.
7177.130 In reply to 7177.129
Hi Stefan
forget about the first version :)
Latest version uses different algorithm and it works much better.
Also it works fine with both MoI 3.0 and 4.0.
EDITED: 7 Mar 2022 by SMIRNOV
7177.131
Voronoi.v.1.11.2018.03.09
Made some performance improvement (thanks to Stefan)
http://moi.maxsm.net/item/48
WOW Max,
thanks a lot! I will then use your new version immediately! :-)
Best regards
EDITED: 9 Mar 2018 by STEFAN
Message 7177.133 deleted 9 Mar 2018 by GLMR
My Moi French Site My Gallery
Hi Max,
i just tested the new version, amazing!
(Did a quick PayPal donation. :-))
Best regards
7177.136 In reply to 7177.135
Hi Stefan
Thank you! :)
Hi Max,
I have to thank you...!!!
I think i have some ideas, inspired by Pilou's recent image (the spiral),
for some new doodles. :-)
Best regards
7177.138 In reply to 7177.131
This is the only word that comes to mind :)
A big thank to you Max!!
Hello everyone!
Thanks you very much Michael and Max for what you're doing ;)
Inspired and intrigued by the works of Stefan I had some fun with new Voronoi and some points :)
Check this video : http://take.ms/WOrWI
And this is the 3dm file is you want to play with it : http://take.ms/QKKdM
Ciao!
Marco (mkdm)
P.S...forgot to mention...
Clearly I was inspired also by the latest experiments of Pilou!
7177.141 In reply to 7177.139
Very cool Marco!
On your various curve shapes...how are you going from control points to the individual points on the curve/path to create the Voronoi? As I experiment, I only get control points for the path. I "rebuild" the curve with # of points but I still get connected control points on a given curve/path.
Thx.
7177.142 In reply to 7177.131
Amazing update as usual Max! Thanks!
Question though...
In the updated Voronoi.v.1.11.2018.03.09 script...is there a way to create a Voronoi without having an outside edge/border automatically generated?
Would be nice to have a checkbox option for border/no border. The older Voronoi script from 2015 didn't generate a border if I recall...which was great for certain things.
Screen Shot A (from 2015 Voronoi script) > Open outside border Voronoi is what I'm looking to do with the 2018 script.
Screen Shot B > Individual cells created from running Voronoi script...which creates outside square border.
Screen Shot C > After using the "separate" function to break the cells down to delete the outside square edges...makes a mess with all the duplicate curves from each cell to get an open edge Voronoi.
Thx!
7177.143 In reply to 7177.142
just fun with Voronoi > blendcap > flow and Keyshot
EDITED: 9 May 2020 by FINEMA
7177.144 In reply to 7177.141
Hi mat,
One way to do this is to create one point object on the curve (anywhere on a closed curve or at one end of an open curve) using Draw curve > More > Pt and then select the point you just created and replicate it along the curve using Transform > Array > Curve.
7177.145
Exported to Modo and used mesh-ops to bevel and convert to quads for Catmul-Clark sub-division.
EDITED: 18 Oct 2018 by SBEECH
7177.146 In reply to 7177.144
Cool Marco, Finema and danperk!
> One way to do this is to create one point object on the curve (anywhere on a closed curve or at one end of an open curve) using > Draw curve > More > Pt and then select the point you just created and replicate it along the curve using Transform > Array > > > Curve.
Oh Michael, i think you opened up tons of possibilities for us now, with this cool tip... :-)
I just used this for a Voronoi Text example were i increased the points to get a nicer text pattern.
Combining this now with extrusions and NSided caps and later bringing it into ZBrush, for
example, should bring up lot of cool things not seen before, when it comes to 3D text models
renderings... :-)
EDITED: 10 Mar 2018 by STEFAN
I mean something like this, not finished of course.
But IMHO the pattern looks now nicer, because of the evenly
spaced denser points.
Bildschirmfoto_2018-03-10_um_22.43.12
Show messages:  1-7  …  68-87  88-107  108-127  128-147  148-167  168-187  188-198
