Voronoi Script or plugin
 1-18  …  79-98  99-118  119-138  139-158  159-178  179-198
7177.119 In reply to 7177.117
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
<< select points and run voronoi script
So... :)
7177.121
Alberto
>>some hope of having Voronoi tool in Nodeeditor ....
I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.
Marco
>>The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;)
For leaves or fish's bones :)
EDITED: 9 Mar 2018 by PILOU
7177.123 In reply to 7177.120
WOW !!!! Super coooool!!!!
Thanks!
7177.124 In reply to 7177.121
Hello Max!
@You : "...Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;).."
OK Max :)
Thank you very much for all your amazing plugins!!
7177.125
Hi Max
Maybe after that I'll add voronoi node.<<
good sound for me , are your words
what else to say ...
good work and we hope to meet soon
Voronoi Node
have a nice day
alberto
7177.126 In reply to 7177.117
Thank you Max:-)
Message 7177.127 deleted 9 Mar 2018 by GLMR
7177.128 In reply to 7177.126
Hi Max,
i tried your script (old version) under OS X with 5000 points but i don't get the desired result.
For comparison i attach pictures from Adrian Secord's Weighted Voronoi Stippler (2) and MoI (1) script output.
I used his points output for x,y and added with sed z = 0.0000000 coordinates.
Attached is also the points file.
O.k. scaled now with factor 100, much better, but still not there.
Maybe i have to try MoI v4 with your latest version.
7177.130 In reply to 7177.129
Hi Stefan
forget about the first version :)
Latest version uses different algorithm and it works much better.
Also it works fine with both MoI 3.0 and 4.0.
EDITED: 7 Mar 2022 by SMIRNOV
7177.131
Voronoi.v.1.11.2018.03.09
Made some performance improvement (thanks to Stefan)
http://moi.maxsm.net/item/48
WOW Max,
thanks a lot! I will then use your new version immediately! :-)
Best regards
EDITED: 9 Mar 2018 by STEFAN
Message 7177.133 deleted 9 Mar 2018 by GLMR
My Moi French Site My Gallery
Hi Max,
i just tested the new version, amazing!
(Did a quick PayPal donation. :-))
Best regards
7177.136 In reply to 7177.135
Hi Stefan
Thank you! :)
Hi Max,
I have to thank you...!!!
I think i have some ideas, inspired by Pilou's recent image (the spiral),
for some new doodles. :-)
Best regards
7177.138 In reply to 7177.131
This is the only word that comes to mind :)
A big thank to you Max!!
Show messages:  1-18  …  59-78  79-98  99-118  119-138  139-158  159-178  179-198
