Voronoi Script or plugin
 1-9  …  70-89  90-109  110-129  130-149  150-169  …  190-198
Hello everyone!
I admit I was tempted to create on the fly a brand new thread but I want to submit this thought to all "colleagues" moiers :)
The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
I think it should deserve much more than this but anyway...tell me what do you think ?
Best thanks is use the Max's scripts! ;)
My Moi French Site My Gallery
7177.112 In reply to 7177.111
Yes Pilou!
You're right...but I think that maybe a public thank could b a nice thing for him....I don't know :)
7177.113
Thanks Max!
EDITED: 18 Oct 2018 by SBEECH
With the little trick above :) http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.81
(2 different grids Isected then ExplodeMoved: one with Corners =0, other Corners = 100 )
PS Subdiv (not applied here) don't works with all volumes ( surely some > 5 polygons! )
EDITED: 8 Mar 2018 by PILOU
7177.115 In reply to 7177.114
Very nice!
A sort of "fragments of an exploded planets" :)
Is it possible to add a file of points, as input to the voronoi script?
7177.117 In reply to 7177.116
Hi Brian
you can use ImportPointFile script (http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile)
then select points and run voronoi script
7177.118
Hi Max
Thanks for all
some hope of having Voronoi tool in Nodeeditor ....
alberto
7177.119 In reply to 7177.117
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
<< select points and run voronoi script
So... :)
7177.121
Alberto
I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.
Marco
Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;)
For leaves or fish's bones :)
EDITED: 9 Mar 2018 by PILOU
7177.123 In reply to 7177.120
WOW !!!! Super coooool!!!!
Thanks!
7177.124 In reply to 7177.121
Hello Max!
@You : "...Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;).."
OK Max :)
Thank you very much for all your amazing plugins!!
7177.125
Hi Max
Maybe after that I'll add voronoi node.<<
good sound for me , are your words
what else to say ...
good work and we hope to meet soon
Voronoi Node
have a nice day
alberto
7177.126 In reply to 7177.117
Thank you Max:-)
Message 7177.127 deleted 9 Mar 2018 by GLMR
7177.128 In reply to 7177.126
Hi Max,
i tried your script (old version) under OS X with 5000 points but i don't get the desired result.
For comparison i attach pictures from Adrian Secord's Weighted Voronoi Stippler (2) and MoI (1) script output.
I used his points output for x,y and added with sed z = 0.0000000 coordinates.
Attached is also the points file.
O.k. scaled now with factor 100, much better, but still not there.
Maybe i have to try MoI v4 with your latest version.
Show messages:  1-9  …  50-69  70-89  90-109  110-129  130-149  150-169  170-189  190-198
