Voronoi Script or plugin
 1-2  …  63-82  83-102  103-122  123-142  143-162  …  183-198
7177.103 In reply to 7177.102
Thank you very much Max!!
Are you running for a prize ? :)
It seems that this Voronoi plugin is a sort of personal challenge for you.
Great job, great job Max!!!
Only a question, if I may...
I did some test but I can't figure out how the new "Filter" affects the output of the Voronoi.
Could you please write something about it ?
Thanks again.
7177.104 In reply to 7177.102
My Moi French Site My Gallery
7177.105 In reply to 7177.103
Hi Marco
No, it's not a challenge. I just want to make a good script and then forget about it.
It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider.
7177.106 In reply to 7177.105
Ciao Max!
@You : "...It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider..."
Perfect! Got it.
Tested and now is...perfect!!
@You : "...I just want to make a good script and then forget about it..."
OK! Then you can sleep soundly :) You created an AMAZING script.
Thanks a lot for all your effort.
Ciao!
7177.107 In reply to 7177.105
Max...your wanderful script gave me an inspiration..."How to brake in two each Voronoi cell and make a funny thing"
Look at this video : http://take.ms/pBFZS
In short the process I have used is :
1 Select all Voronoi curves
2 Apply the "mark curve start" plugin
3 Select again all Voronoi curves
4 Apply the "mark curve middle point" plugin
5 Trim the Voronoi curves with the generated points of steps 2 and 4
6 Close all the "half curves" with the command "closecurve"
You can download all the plugins I've used at : http://take.ms/uAgYy
Unzip and copy the files into the Moi's "commands" folder.
THOSE CUSTOM COMMANDS WHERE TESTED WITH MOI V3
I suppose they should work also with Moi V4 but I didn't try)
Ciao!
7177.108 In reply to 7177.107
P.S....forgot to say that I've used also another Max's custom command : "PatternSelection"
You can grab it here : http://take.ms/0F9I8
Ciao!
7177.109 In reply to 7177.105
I was waiting for this moment sooo long. Now your script is perfect, just perfect! Thank you very much!
Hello everyone!
I admit I was tempted to create on the fly a brand new thread but I want to submit this thought to all "colleagues" moiers :)
The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
I think it should deserve much more than this but anyway...tell me what do you think ?
Best thanks is use the Max's scripts! ;)
7177.112 In reply to 7177.111
Yes Pilou!
You're right...but I think that maybe a public thank could b a nice thing for him....I don't know :)
7177.113
Thanks Max!
EDITED: 18 Oct 2018 by SBEECH
With the little trick above :) http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.81
(2 different grids Isected then ExplodeMoved: one with Corners =0, other Corners = 100 )
PS Subdiv (not applied here) don't works with all volumes ( surely some > 5 polygons! )
EDITED: 8 Mar 2018 by PILOU
7177.115 In reply to 7177.114
Very nice!
A sort of "fragments of an exploded planets" :)
Is it possible to add a file of points, as input to the voronoi script?
7177.117 In reply to 7177.116
Hi Brian
you can use ImportPointFile script (http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile)
then select points and run voronoi script
7177.118
Hi Max
Thanks for all
some hope of having Voronoi tool in Nodeeditor ....
alberto
7177.119 In reply to 7177.117
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
<< select points and run voronoi script
So... :)
7177.121
Alberto
I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.
Marco
Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;)
For leaves or fish's bones :)
EDITED: 9 Mar 2018 by PILOU
Show messages:  1-2  …  43-62  63-82  83-102  103-122  123-142  143-162  163-182  183-198
