MoI and Octane for Rhino
All  1-3  4-6
7166.4 In reply to 7166.3
I think I understood what Eric is asking.
Of course if you use the same file lots of informations will be lost once you open it in moi again and save.
My solution is to have a separate .3dm file that you will use only with Rhino+Octane (eg. MyProject-Render.3dm); if you need to make any modifications to the model, you can use moi and then replace\add only the part that you changed into the render 3dm file.
M.
7166.5 In reply to 7166.4
Hi Michael ...
Here are a couple of screenshots that show the difficulty. One is the material as it appears in Rhino after the material from the Octane database is attached to the file.
The other (screenshot 2) is after this file has been saved in MoI and opened again in Rhino. It has lost its attributes. Yes, as wastzzz points out, if the primary file is Rhino/Octane one can use MoI independently to create objects that can be imported into the primary file.
I hope for a time when MoI will retain the material information when one uses the same file for flipping back and forth. As I said earlier, if this is a big job or impossible just let it go as the workaround is an OK way to handle the problem.
cheers,
eric
7166.6 In reply to 7166.5
Hi eric can you please e-mail me (at moi@moi3d.com) the 2 3DM files that correspond to each of those screenshots so I can examine them? Thanks.
Show messages: All  1-3  4-6
