Best software?
7147.1
Hi, I am looking for solution for the attached picture as not sure what would be the best software.
Can you suggest something I am thinking about T-spline, Claayoo, Blender Subdiv nurbs, Viacad Subd, Maya LT or formZ.
Size: 428.8 KB, Downloaded: 105 times, Dimensions: 788x540px
7147.2 In reply to 7147.1
Moi will maybe not the best but you can use it for your image! :)
PS You have forgotten the best "ZBrush" ! ;)
25 first minutes
EDITED: 27 Dec 2014 by PILOU
7147.3 In reply to 7147.2
Zbrush can also produce nice things, one of the best in its field, however looking for something with short learning curve.
Would be better to be done in 20 min max. Otherwise geometry analyses how to build and moi 3d as always :)
7147.4 In reply to 7147.3
I don't know any prog without a learning curve! :)
So maybe as your model is symmetric the free Sculptris (very speedy learning curve) will be fine for you!
http://pixologic.com/sculptris/
7147.5
This looks organic and fairly complex. Yeah poly modeling might be the way.
M.
Sure :)
7147.7 In reply to 7147.3
Hi Andras - that type of shape is going to be pretty difficult to model in only 20 minutes in any kind of software I think...
But probably one of the displacement brush stroke based modeling programs like ZBrush mentioned above would be the fastest I would think.
If you've tried ZBrush before and did not like it, then also give 3D Coat, Sculptris, and Blender sculpt mode a try and see if any of those are more comfortable for you.
7147.8 In reply to 7147.7
Hi Michael thanks for the help, Model does not need to be exact and the main problem seems to be solved by Nsided command,
just made some tests earlier but gonna finish it later.
7147.9 In reply to 7147.1
artcam?
7147.10 In reply to 7147.9
Hello,
Try Aspire.. it is made for sculptures like this
Regards, Jan
7147.11
3d Coat is awesome for everything else that MOI can't do. (Sculpting, Texturing etc)
http://3d-coat.com/
