boolean problem
All  1-2  3-8
7136.3 In reply to 7136.1
Geoff, please post .3dm
I'd try trim, but am unsure of your 3d geometry.
7136.4
Sure, here you go. I'm not sure if the background image will cause a problem if it's not found, so I'm attaching that too. Thanks!
Size: 571.5 KB, Downloaded: 37 times, Dimensions: 650x1600px
7136.5
@chipp, they are all on the same axis, but not necessarily on the same plane (z-position). Do they need to be?
7136.6
Using the trim command worked great. But now I'm left with open curves and I'm guessing because they're not on the same plane, that's why they won't join. How do you reposition a curve so it's on the same plane as others? thanks.
7136.7
Nevermind, I figured out how to get them to the same position and after doing that they joined properly. So, thanks everyone for the help!
7136.8 In reply to 7136.7
Hi geoff, I'm glad you got it figured out!
Yes for curve/curve booleans the different curves involved need to be all one the same plane.
Trim on the other hand can deal with "apparent intersections" and can cut things that are on different planes from one another, but you will still need to move them to a common plane in order to join them into one piece after that.
Show messages: All  1-2  3-8
