How to close this surface?
All  1-7  8-9
7128.8 In reply to 7128.6
Hi Chipp, I'm glad you got it finished!
See my post above for a quicker way - all you need to do is select your sweep and then run the Construct > Planar command. That then automatically finds closed sets of naked edges that are planar, builds planar surfaces in those spots with those edge curves being the boundaries, and also joins the pieces together for you. So you should get a closed solid just after selecting your sweep and running that one command.
7128.9 In reply to 7128.7
Thanks Michael. Didn't know about the 2nd way to use Construct > Planar. Helpful!
Show messages: All  1-7  8-9
