How to close this surface?
All  1-5  6-9
7128.6
OK. I figured it out. Here's what I did.
1. After SWEEP, this small curve was generated at each corner. I then QUARTERED the model and threw away 3 of the quarters.
2. I constructed small lines to enclose the curve (co-planar to back surface) and then built out the long slim surfaces to boundary the pie shaped slice.
3. I then created the rest of the back using the straight lines from the slim surfaces. Joined everything and checked for 'leaks' (N key) and it was all good. So I mirrored and joined and voilĂ , a Solid!
File:
https://altuit.cloud/web/dbpub/3D/NextBook05.3dm
EDITED: 19 Dec 2014 by CHIPPWALTERS
7128.7 In reply to 7128.4
Hi Chipp, sorry yeah just going by your image above and not the 3DM file I thought that your corners were exactly the same radius as the size of the profile curve, making things pinched to an exact single point on one side. But with your upload I can see that there is a little space in there so you should be ok.
Your file is all set to be made into a solid, just delete the bottom face that you had previously built so that you only have the sweep, then select the sweep and run the Construct > Planar command. That will build end caps on the planar openings of the object and join them in automatically so you'll have a solid as the result after running just that one command.
The Construct > Planar command can work in 2 different ways, you can give it a set of planar curves to build a planar surface from (in which case you will need to also additionally join the pieces together with Edit > Join afterwards), or the second way to use Construct > Planar is to give it a surface object that has open edges in it and it will find sets of open edges that are planar, build planar faces out of them, and join them together all in one go which is pretty convenient.
So anyway the upshot is to just run the Construct > Planar command when you finish your sweep and that will get you the result you need I think.
7128.8 In reply to 7128.6
Hi Chipp, I'm glad you got it finished!
See my post above for a quicker way - all you need to do is select your sweep and then run the Construct > Planar command. That then automatically finds closed sets of naked edges that are planar, builds planar surfaces in those spots with those edge curves being the boundaries, and also joins the pieces together for you. So you should get a closed solid just after selecting your sweep and running that one command.
7128.9 In reply to 7128.7
Thanks Michael. Didn't know about the 2nd way to use Construct > Planar. Helpful!
Show messages: All  1-5  6-9
