UnwrapCurve script error
All  1-7  8-18
7125.8
Thank you all but I've checked everything.
UnwrapCurve - no space before it. Tried _UnwrapCurve - made no difference.
The files automatically unzip when I download them to my mac. I copy both files to the correct folder. Also, I make sure Moi3d is closed when I copy the files.
Still baffled..
Gunter
7125.9
Another thought... this only happened after I downloaded the latest version of moi v2.... v2.52
Before this UnwrapCurve worked fine.
Just thought I'd let you know..
Gunter
7125.10 In reply to 7125.9
Hi Gunter.
Do all of your other shortcut keys work properly? I would try to disable a different one, say SineWave, by misspelling it in
the Commands folder say as SSSineWave, and seeing if it disables. This would indicate the wrong Commands folder???
Note that the UnwrapCurve names all have to be spelled the same, without leading or trailing spaces.
In the Commands folder:
UnwrapCurve.js
UnwrapCurve.htm (not .html)
Under Shortcuts:
Key: (for example U), Command: UnwrapCurve
Edit: I still think it is whitespace :-)
EDITED: 14 Dec 2014 by BEMFARMER
7125.11 In reply to 7125.9
Hi Gunter, I tested UnwrapCurve over here with v2.52 on OSX myself and it's working fine for me...
One other thing to check - when you downloaded UnwrapCurve.zip, the automatic unzipper thing probably made a folder named "UnwrapCurve" with the 2 files contained inside of it.
When you copied things over to the commands folder, did you possibly copy the folder named "UnwrapCurve"? If so then that's the problem - MoI won't find the files if they are contained in some sub-folder, the 2 command files have to be present directly inside the commands folder and not nested in some additional folder structure inside of it.
I'm not sure of what else to tell you , other than to triple check the shortcut and that the files are copied as they need to be.
7125.12 In reply to 7125.10
I tested ReconstructCurve and that also does not work. The other commands seem to work.
Here is where I pasted my files..
I wish it was whitespace but it's not...
Still stuck but thanks.
Gunter
EDITED: 15 Jul 2024 by GUNTER511
7125.13 In reply to 7125.11
I copied only the files not the folder.
What is odd is that the Reconstructcurve command also does not work. Please see the snapshots of where I pasted the files and
my shortcut menu.
I even tried deleting moi and reinstalling it. That didn't work either.
Stumped but thanks.
Gunter
7125.14 In reply to 7125.13
Hi Gunter, do you possibly have OSX installed on a "case-sensitive" disk partition?
If so then maybe try making your shortcut say UnwrapCurve (note the capital letter C in Curve), right now you have Unwrapcurve with lower case c...
Just grasping at straws here...
7125.15 In reply to 7125.14
I just changed the C to caps.
Same deal :(
Gunter
7125.16
Michael, Brian et.al.
You're all going to want to throttle me!
I feel like a complete ass.
I finally figured it out. What happened was when I downloaded moi again, I clicked on the moi.app icon and then just right clicked to keep it in the dock. I did not
physically drag it into the applications folder. Since it was in my dock, I assumed it was in the applications folder.
Now, after downloading it, I dragged it into the Applications folder and then tried it. It works.
I'm so sorry for wasting everyone's time.
Apologies. And thank you all for your super prompt support.
Gunter
7125.17 In reply to 7125.16
No problem Gunter, I'm glad you've got it working now!
7125.18 In reply to 7125.17
Thanks Michael!
Show messages: All  1-7  8-18
