How To Sweep?
All  1-3  4-5
7099.4 In reply to 7099.1
The "project and get side rails" way would be like the attached.
You can now select the arcs and run sweep and use the 2 open edges (which are projected trims from the 2 lines) as the rails.
The resulting sweep will hug the surfaces and will have the shape you want at each end of it, but it won't be guaranteed to be smooth on the inside areas. Generally only fillet or blend will yield something that is a smooth connection between 2 existing surfaces.
7099.5
Thanks for explaining. Very much appreciated. I'll take a look.
I ended up using loft to create the basic shapes. Then I tweaked the originating curves to the correct side/top profiles which was great as the lofted shape adjusted instantly as I tweaked. Super for 'fine-tuning' a shape. Lastly, I deleted the loft shape, added fillets as I liked and re-lofted. I tried adding fillets with the 'live' loft but things got weird fast. Seems like the "Samardac Method" is a great one for parametric-like modeling. :-)
Show messages: All  1-3  4-5
