Matching MoI and Keyshot camera
 1-10  11-22
7093.11 In reply to 7093.1
Hi Martin, it could be possible that MoI and Keyshot measure the field of view slightly differently.
MoI measures it such that field of view covers the innermost square of the viewport, meaning the lesser of either the width or height of the image. This is so if you change the viewport size to different aspect ratios the field of view kind of adapts to the size.
Many rendering programs measure it strictly by image width. So you may need to incorporate a modifying factor of your image width/height aspect ratio into there to get it to match.
7093.12
Hi Martin,
if you import the .3dm-file into KeyShot the camera of the 3D-view of MoI comes with it.
Would be great to have saved views in MoI for such cases.
Hope that helps.
7093.13 In reply to 7093.12
Thanks Jay,
is importing .3dm a KeyShot PRO feature? Because when I try to import a MoI 3dm file I get this
7093.14 In reply to 7093.13
Hi Martin.
Keyshot 5 Pro is required to directly import Moi .3dm NURBS data.
Keyshot 5 HD version does not do so.
As I recently learned here: http://moi3d.com/forum/index.php?webtag=MOI&msg=7096.1
But you can easily shade the .3dm in Rhino5, if you have it, for import into KS5HD version
- Brian, beginning KeyShot user
EDITED: 3 Dec 2014 by BEMFARMER
7093.15 In reply to 7093.14
Thanks for clarifying this Brian.
Thanks to Frenchy Pilous Black Friday hint I'm now also a beginning Keyshot user :-)
The original price was always too high for me.
Maybe I upgrade to Pro on the next Black Friday.
-Martin
7093.16
One of the problems with importing the nurbs directly, is you cannot take advantage of Keyshot's *rounded edge* rendering-- which is quite a popular feature for many Industrial Designers.
Still, it would be great if there was a documented workflow which allowed for MoI wire overlays. A few of ideas:
1. MoI import Keyshot camera settings (I suspect this would have to be done manually AFAIK Keyshot's bip format is not open).
1a. If this is possible, then MoI could possibly composite the final is the bg image of a viewport was set to the Keyshot image.
2. MoI exports a scene format which correctly matches Keyshots upon import. Compositing would have to be done in a third party program.
3. Keyshot creates a mode which renders the NURB wires on top of existing model. In this case MoI does nothing ;-)
4. A Keyshot plugin would also be good if it would export both NURBS and/or OBJ. I prefer OBJ because of the previously mentioned *rounded edge* renders.
7093.17
After loading the .3dm-file you can import the .obj as well. So "Rounding Edges" are no problem.
I did a comparison of a MoI-KeyShot-matched camera setting. Unfortunately I can't translate the settings from one to the other.
I suppose somewhere is a website where you can convert such settings but couldn't find it anymore.
Maybe somebody knows a way to transfer those camera-settings.
7093.18 In reply to 7093.17
Hi Jay, probably using the "Absolute" method would be your best bet. Did you push the "Select Look at point" button to put in the MoI target point as well?
You might try putting x = 0, y = 1, z = 0 for the up direction, and then the one that may be a bit tricky is matching the field of view.
Moi measures field of view as the angle covered by the innermost square in the view plane, meaning the minimum of either width or height.
Probably KeyShot is measuring it as across the entire image width. So you may need to do a conversion factor of multiplying the MoI field of view value by a scale factor of render image width / height.
7093.19
here is another matched Camera of Keyshot.
I don't really come through. I just wanted to know if it is reconstructable and maybe would work into the other direction. (KeyShot -> MoI)
A the moment for me it's ok to work with:
Making screenshots of the different camera-settings in MoI.
To generate a MoI-camera in KeyShot update the .3dm-file wich has the last camera-settings stored. tx
7093.20 In reply to 7093.19
Hi Jay - what does the difference between the 2 views look like? Are they at least centered on the same spot or is that not the case either?
What is your pixel width and height resolution that you are rendering at in KeyShot?
7093.21
Sorry for the delay all the time.
I would say it is centered.
Actually I use in KeyShot a resolution of 2217 x 1364 pixels.
After overlay an proportional transformation you will get this:
7093.22 In reply to 7093.21
Hi Jay,
So for field of view, try multiplying your MoI field of view by 2217 / 1364
So for example if you have a field of view in MoI of 10 and you are rendering at 2217 by 1364, do
(2217 / 1364) x 10 = 16.254
Does that make a better match?
Show messages:  1-10  11-22
